Bonnet Scoops
You still running a maf? Looks like those may scoop in rain as well as air and short it out of you do.
Been running with 1 scoop for a while now and no problems so far,but point taken.
Original bonnet scoops for me and i would have the original headlights also as there looks to be a bit of a miss-match between the centre-grill and bonnet alignment with those headlights.
Could we just stick to the bonnet scoops as we have already had the discussion on the headlights !! We all know they are meant for the facelift model......but hey ho they are staying.
I took advice with something similar when i had my last scoob and decided against it . Same issues as Colin has mentioned..Rain getting to the Maf and air coming in where not needed.. For better air flow ..you thought about a slightly bigger bonnet scoop to the I/c ?
Prefer the standard vents TBH..
And if you thinking of performance, they will just add drag, disturb the airflow over the car and act as bonnet lifters.. Can't really see the point myself..
All IMHO...
Edited by ScoUK
you can stick whatever you want on your car
it looks fantastic.
Lights are smart :thumbup: Scoops nope :driving:
I only used my one on the drivers side when I was on track
due to the amount of stick it was getting I thought the more air in the better
on normal road use I wouldnt bother
but it's up to you, if you like it then go for it
As been said before mate, the original vents look better, imo.
Are the new scoops Carbon Fibre, if not they may look better colour coded silver to match your car.
End of the day though, its your car so if your happy then great :thumbup:
prefer standard ones, the new ones just remind me of all the old school boy racers that stuck the teardrop escort cosworth vents on there 1.1 fiestas
lights are growning on me thou
I used to have the mini bonnet scoops, removed them after 1 rain shower. The air cone was wet through and the maf was fecked, I ended up buying a new air cone & maf.
