Some help please
When towing my Pug home tonight the "check engine" light came up on my speedo. we were on the Edinburgh bypass at the time and couldn't stop so we had to drive about 5 miles before it went out. Any ideas?
Engine management lights can be even the slightest thing,if the engine starts running erratically,then there is a problem,missfire,air mass sensor,tons of things.If the car is still running fine dont worry it was just a glitch.If you get the chance subaru will check the fault code and let you know what it was,if you can be arsed. face-icon-small-wink.gif
I would suggest towing the Scoob with the Puggy from now on , rather than the other way round face-icon-small-happy.gif
Other than that, you are going to have to find out if there is a fault code stored 1st before you try anything else.
If you modified it & fitted gauges you might have been able to miss out the above step as they might have given you warning face-icon-small-wink.gif
<< daz ----- wish you would post some more ....... your avatar is face-icon-small-tongue.gif >>
More than a little hypnotic. I could watch that all day.... face-icon-small-smile.gif
