Oil & Spark Plugs
<< buy blitz iridium plugs fee your car deserves the best face-icon-small-wink.gif >>
Um no i would avoid these like the plague! NOT good for a scoob at all.
PFR7B's are what you want if you have a modded car, if not use PFR6B's.
had to change NGK plugs twice in 3mths had blitz in for 1 yr had them out for a look and still perfect so blitz gets my vote .first NGK cracked second time tip distorted so put off big time not a 2 min job to change them on a scoob.
<< had to change NGK plugs twice in 3mths had blitz in for 1 yr had them out for a look and still perfect so blitz gets my vote .first NGK cracked second time tip distorted so put off big time not a 2 min job to change them on a scoob. >>
I think the majority of scoob owners have no problem with the NGK's (they are standard equipment after all!) but i have heard of more problems with the iridium tips than anything. Harvey Smith even had to have a rebuild due to the tip breaking off and basically it damaged the cylinder and he hates them now. My experience is that they don't last very well compared to the NGK's anyway.
Just my opinion btw.
For low/med boost and mods then 0.7mm as the boost goes higher then 0.6mm then 0.5mm for very high boost/power. I run 330bhp/320lbsft and have a 0.6mm gap.
Hope that helps
Stuart
  • 1 month later...
There was a good test on the Project RA in Jap performance this month showing the difference between using standard NGK plugs and iridium ones with a recessed tip (can't remember make but may have been Blitz).
The car dropped power HUGELY - something like 25 BHP and the manufacturer admitted these should be fitted mainly for reliability reasons.
They reckoned that the standard NGK plugs (or equivalent quality) were best on the rollers (and during mapping) for their car running circa 330 BHP and similar torque.
If it says 10w-60 anywhere in your handbook I'll eat my stetson!
Post 2000 scoobs use 5w-40 fully synthetic unless modified out of site and used on track
Pre 2000 scoobs use 10w-50 or 15w-50.
Check your handbook and see what it says before using 10w-60!
Simon
