Robbie09 Posted July 8, 2020 Share Posted July 8, 2020 Will these fit a classic My 99 the seller seems to think they do I just want to double check before buying https://www.ebay.co.uk/itm/174198811083?ul_ref=https%3A%2F%2Frover.ebay.com%2Frover%2F0%2Fe11051.m43.l1123%2F7%3Feuid%3D1b00909e1a244a41b2b2498489bff9f7%26bu%3D43120173249%26segname%3D11051%26crd%3D20200708035352%26osub%3D-1%7E1%26ch%3Dosgood%26loc%3Dhttps%253A%252F%252Fwww.ebay.co.uk%252Fulk%252Fitm%252F174198811083%26sojTags%3Dbu%3Dbu%2Cch%3Dch%2Csegname%3Dsegname%2Ccrd%3Dcrd%2Curl%3Dloc%2Cosub%3Dosub%26srcrot%3De11051.m43.l1123%26rvr_id%3D0%26rvr_ts%3D2e1ead4b1730a6e5b4265c80ffd7c373&ul_noapp=true Link to comment
t5nyw Posted July 12, 2020 Share Posted July 12, 2020 On 8/7/2020 at 12:11, Robbie09 said: Will these fit a classic My 99 the seller seems to think they do I just want to double check before buying https://www.ebay.co.uk/itm/174198811083?ul_ref=https%3A%2F%2Frover.ebay.com%2Frover%2F0%2Fe11051.m43.l1123%2F7%3Feuid%3D1b00909e1a244a41b2b2498489bff9f7%26bu%3D43120173249%26segname%3D11051%26crd%3D20200708035352%26osub%3D-1%7E1%26ch%3Dosgood%26loc%3Dhttps%253A%252F%252Fwww.ebay.co.uk%252Fulk%252Fitm%252F174198811083%26sojTags%3Dbu%3Dbu%2Cch%3Dch%2Csegname%3Dsegname%2Ccrd%3Dcrd%2Curl%3Dloc%2Cosub%3Dosub%26srcrot%3De11051.m43.l1123%26rvr_id%3D0%26rvr_ts%3D2e1ead4b1730a6e5b4265c80ffd7c373&ul_noapp=true now sold And to honest not really sure, some newage wrx parts genericaly fitted to a classic but with lots didnt. really need to compare chassis numbers agaist parts manuals etc to be sure. Don is master on parts. tony @The Don Link to comment
The Don Posted July 14, 2020 Share Posted July 14, 2020 As far as I can tell a UK MY99 Turbo 2000 is fitted with the following rear drive shafts which are handed and are fitted to models below. The last of the rear driveshafts fitted to the UK MY00 Turbo 2000 - there are 3 different part numbers - being RH:28021FE140/141; LH: 28021FE150/151, were also fitted to the Newage WRX WAGON upto and including MY04 Just to confirm, a UK MY99 will have an "X" as the 10th character of the VIN and a "G" as the 4th character of the Applied model code. MY00 will have a "Y" and "H" respectively Link to comment
Robbie09 Posted July 14, 2020 Author Share Posted July 14, 2020 The 4th character on mine is G and the 10th X So on that assumption it won’t fit ?? ive bought it now it’s just this minute arrived they look very very similar but not quite an exact match ! Link to comment
