scoobyjoff Posted March 9, 2018 Author Share Posted March 9, 2018 Well if you find any pumps let me know lol Link to comment
The Don Posted March 9, 2018 Share Posted March 9, 2018 2 hours ago, scoobyjoff said: Also would i need to bleed the system as ive removed the hose to replace the "O" ring By moving the steering left to right it should bleed itself. CHANGE the fluid !! make sure the front wheels are off the ground when moving steering from left to right with engine running to make circulating the new fluid easier. Link to comment
ccrien Posted March 10, 2018 Share Posted March 10, 2018 (edited) Hi Joff, if you haven't got a big syringe to get the old fluid out of the reservoir, get a cheap Turkey Baster with a long nozzle and use that. You can get a couple of hundred ml out at a time, replace with fresh fluid and turn the wheel side to side a few times as Mr Don said, which circulates and mixes the fluid,( and pushes any air out ) then replace another portion. Keep going till you've used up most of a litre bottle of fluid. When you say " groans under load",. If you mean groans on or near full lock,. Like the car salesman says " they all do that, sir". Edited March 10, 2018 by ccrien Link to comment
The Don Posted March 10, 2018 Share Posted March 10, 2018 56 minutes ago, ccrien said: Hi Joff, if you haven't got a big syringe to get the old fluid out of the reservoir, get a cheap Turkey Baster with a long nozzle and use that. You can get a couple of hundred ml out at a time, replace with fresh fluid and turn the wheel side to side a few times as Mr Don said, which circulates and mixes the fluid,( and pushes any air out ) then replace another portion. Keep going till you've used up most of a litre bottle of fluid. When you say " groans under load",. If you mean groans on or near full lock,. Like the car salesman says " they all do that, sir". Refer to post #5 Link to comment
ScoobieFloz Posted March 10, 2018 Share Posted March 10, 2018 57 minutes ago, ccrien said: Like the car salesman says " they all do that, sir". Link to comment
scoobyjoff Posted March 10, 2018 Author Share Posted March 10, 2018 Well got as much of the old fluid out as possible with a turkey baster topped up with new fluid and moved steering lock to lock for around ten mins and up to now no more squeal and no more notchy steering and no more groaning pump so hopefully jobs sorted ill try it in a few hours after its settled a bit Link to comment
ccrien Posted March 10, 2018 Share Posted March 10, 2018 (edited) Now that sounds like a RESULT for perserverance! And Don's original diagnosis and advice. Hopefully OK in a few hours then in the morning. Edited March 11, 2018 by ccrien Link to comment
scoobyjoff Posted March 10, 2018 Author Share Posted March 10, 2018 Lets hope so ccrein as it was doing my nut in Link to comment
scoobyjoff Posted March 10, 2018 Author Share Posted March 10, 2018 Lol cheers mr don for you help Link to comment
leon77 Posted April 15, 2018 Share Posted April 15, 2018 Well finally got the car back and no squeal was just down to a lose belt the difference is amazing.... new oil change and all filters new plugs and all fluid change mot on monday so fingers crossed really looking forward to a good run out soon Link to comment
leon77 Posted April 22, 2018 Share Posted April 22, 2018 MOT complete she flew strait through...... now it' time chaps to give these machines a good blast.... just about to leave for a drive round the malverns enjoy the sunshine..... Link to comment
