Plug Posted October 30, 2009 Share Posted October 30, 2009 Bit of a problem, which I've never experienced in a Scoob before. The brakes on the new Scoob are fine - plenty powerful enough etc. and they are completely silent when moving forwards. However, they squeal like a piggy if you even touch the pedal when reversing. Now, I don't know about you, but I don't spend a lot of time going backwards so this isn't a show-stopper; but it is a bit annoying. Any idea what the cause could be? As far as I know, the brakes are standard.. Cheers, Plug Link to comment
tony_eldridge Posted November 2, 2009 Share Posted November 2, 2009 Bit of a problem, which I've never experienced in a Scoob before.The brakes on the new Scoob are fine - plenty powerful enough etc. and they are completely silent when moving forwards. However, they squeal like a piggy if you even touch the pedal when reversing. Now, I don't know about you, but I don't spend a lot of time going backwards so this isn't a show-stopper; but it is a bit annoying. Any idea what the cause could be? As far as I know, the brakes are standard.. Cheers, Plug Mine used to do that too. What brakes do have? Mine are Brembo and only when reversing they used to squeal really badly. What i'd do, did infact, is get the back end up and remove the pads, give the whole caliper a good clean out, rub some copper grease on to the back of the pad, and a little onto the anti-squeal shim. I went a little further as i replaced the standard pads in mine for EBC yellowstuff. Mine hasn't squealed now for over 8 months since i did Link to comment
pezza_no1 Posted November 4, 2009 Share Posted November 4, 2009 Mines exactly the same, squeel like a pig when reversing. When it was in for a service I asked Subaru about it and they said they just wanted to be copper greased and that should cure it... They also wanted £80 for the pleasure so I kindly said no thanks to that, but haven't got around to doing them myself as yet! Link to comment
andyjudge Posted November 4, 2009 Share Posted November 4, 2009 Mine do that as well a a clonk when engaging the brakes when reversing. Its down to missing anti-Squeal/rattle shims when I changed over the pads ( They wouldn't fit) Copper Grease does sort it for a while though, ( Must remember to redo mine this weekend) Andy Link to comment
Gary WRX Posted November 4, 2009 Share Posted November 4, 2009 Sounds like I need to do the same as I have the same issue although saying that I do not reverse that often so not much of a problem for me if no longer term damage is caused Link to comment
