RA Dunk Posted February 6, 2009 Posted February 6, 2009 went to head out a couple of hours ago started the car and let it heat up with the turbo timer set to three minutes (keys out) went to start it again and its not playing ball, its turning over ok so not the starter, getting prime from the fuel pump ok so not the fuel pump,what would be next to check could it be the spark plugs?
euan_r Posted February 6, 2009 Posted February 6, 2009 think its crank sensor next to give spark. funny foo its was fine one minute and nae the next. another possibility could be coolant sensor hence why its started when cold but being funny once warmed up. ony bother afore starting.
RA Dunk Posted February 6, 2009 Author Posted February 6, 2009 think its crank sensor next to give spark. funny foo its was fine one minute and nae the next. another possibility could be coolant sensor hence why its started when cold but being funny once warmed up. ony bother afore starting. nope no probs when i parked it up last night, started first time round this morning, just wouldent start second time round once it had heated up a wee bit
euan_r Posted February 6, 2009 Posted February 6, 2009 might be worth trying just noo. if it was coolant sensor its maybe cooled down again noo. will leave a code eventually if its it. you will have same problem starting again though if you drive anywhere and stop though. bar that or the crank sensor im oot of ideas and somebody mare techy will need to take over. ohh just remebered you have simtek so i dinnae ken onything about that.
scientific steve Posted February 6, 2009 Posted February 6, 2009 Could it be to do with the Turbo Timer lad? Have you tried to interficker with that?
Big 'D' Posted February 6, 2009 Posted February 6, 2009 Have you checked the ECU for stored codes yet? Do you know about connecting the 2 wires under the dash to read the codes, if not is all in the scoobypedia under ECU, the subaru specific fault codes are there also. Cheers Iain
RA Dunk Posted February 6, 2009 Author Posted February 6, 2009 Could it be to do with the Turbo Timer lad?Have you tried to interficker with that? had a wee feck around with it but it seems to be normal
RA Dunk Posted February 6, 2009 Author Posted February 6, 2009 Have you checked the ECU for stored codes yet?Do you know about connecting the 2 wires under the dash to read the codes, if not is all in the scoobypedia under ECU, the subaru specific fault codes are there also. Cheers Iain will look into this tomorrow, have just sourced a Cam sensor and new plugs but will need to wait till tuesday before i can pick up a crank sensor might as well get them all done at once TBH, the plugs are only a year old so will try the cam/crank sensors first
RA Dunk Posted February 7, 2009 Author Posted February 7, 2009 i dont know i havent been that far into it yet, i was going to change out the crank sensor and the cam sensor (they need to be done anyway TBH) which is easy enough to do before i started on the plugs
Big 'D' Posted February 7, 2009 Posted February 7, 2009 Any joy getting your car started yet? Cheers Iain
RA Dunk Posted February 7, 2009 Author Posted February 7, 2009 nope been too bloody cold to attempt it today
Big 'D' Posted February 8, 2009 Posted February 8, 2009 nope been too bloody cold to attempt it today Fair enough mate, good luck for when you get round to it and dont forget to check the codes first as the ECU will (usually) give you a good idea as to what is wrong with the engine. Cheers Iain
terzo neil Posted February 8, 2009 Posted February 8, 2009 how about plug in the orginal ecu, just in case of a simtek failure
RA Dunk Posted February 8, 2009 Author Posted February 8, 2009 just been out looking for the ECU stored codes, every thing seems to be connected up already though where are these http://www.scoobypedia.co.uk/index.php/Kno...ngECUCodes#toc3 black connectors at?
RA Dunk Posted February 8, 2009 Author Posted February 8, 2009 (edited) just plugged in the old ECU now as well, still not starting Edited February 8, 2009 by Ac!D
Big 'D' Posted February 8, 2009 Posted February 8, 2009 just been out looking for the ECU stored codes, every thing seems to be connected up already though where are these http://www.scoobypedia.co.uk/index.php/Kno...ngECUCodes#toc3 black connectors at? Hi mate, sorry for the delay in reply, chances are the black single pin and green double pin connectors have been tucked up into the wiring loom under the dash on the drivers side, if you have a careful look you will find them they are defo there mate. When you find them connect just the black singe pin ones together and turn the ignition on and count the 'check engine light' flashes slow = x10 and fast = x1 so eg 2 slow and 3 fast = 23 and so on. Multiple codes will have a slight pause between codes. Hope this helps and I hope you find the wires as it could save you a lot of time and hastle if the ecu can point you in the right direction. Cheers Iain
RA Dunk Posted February 8, 2009 Author Posted February 8, 2009 Hi mate, sorry for the delay in reply, chances are the black single pin and green double pin connectors have been tucked up into the wiring loom under the dash on the drivers side, if you have a careful look you will find them they are defo there mate. When you find them connect just the black singe pin ones together and turn the ignition on and count the 'check engine light' flashes slow = x10 and fast = x1 so eg 2 slow and 3 fast = 23 and so on. Multiple codes will have a slight pause between codes.Hope this helps and I hope you find the wires as it could save you a lot of time and hastle if the ecu can point you in the right direction. Cheers Iain will check under the dash tomorrow once its daylight again, cheers for the help so far though
Big 'D' Posted February 8, 2009 Posted February 8, 2009 will check under the dash tomorrow once its daylight again, cheers for the help so far though No problem mate, any time Cheers Iain
marky.t.s Posted February 8, 2009 Posted February 8, 2009 mibbies it just needs a wash and a detail Dunk
RA Dunk Posted February 8, 2009 Author Posted February 8, 2009 mibbies it just needs a wash and a detail Dunk aye maybe, time to break out my finest fairy liquid and a scouring pad then
RA Dunk Posted February 10, 2009 Author Posted February 10, 2009 finally got round to changing the plugs today and finally it runs again, yayyyy
cullenmin Posted February 10, 2009 Posted February 10, 2009 finally got round to changing the plugs today and finally it runs again, yayyyy Nice 1 Dunc, mine was extremely lumpy in driving the other day, kept stalling and wouldnt go into any gear for about 2 minutes. It had been sitting for a good few days though in minus temperatures. I think it was just punishing me for ne keeping it nice and warm Now go have some fun in that snow Rich
RA Dunk Posted February 10, 2009 Author Posted February 10, 2009 What was wrong? it cut out on friday and refused to start again, tried a few different things all of which failed, changed the plugs today and away it went Now go have some fun in that snow it snowed here tonight for about an hour then it had melted an hour later
