cal_type r Posted November 27, 2008 Posted November 27, 2008 Hello folks! Hope your all well. The Scoob is goin into the garage this wknd for the winter and i was wondering if theres any tips or important points to be aware of when putting the car away for 6 months or so Any help much appreciated!
scoobyiain Posted November 27, 2008 Posted November 27, 2008 Take the wheels off and sit in on axle stands. Keep the windows open a fraction.
scooby222 Posted November 28, 2008 Posted November 28, 2008 as above and buy a optimate trickle charger to keep the battery tiptop
JohnSt Posted November 28, 2008 Posted November 28, 2008 you don't need the handbrake on when in the air
RS Grant Posted November 28, 2008 Posted November 28, 2008 When you DO bring it out, it would be worth changing the oil and filter and disconnecting the crank sensor... and turning it over a few times (it wont crank into life with this disconnected), once you've done that, re-connect the plug and fire it up. Cheers, Grant
colin_ross Posted November 28, 2008 Posted November 28, 2008 i was wondering if theres any tips or important points to be aware of when putting the car away for 6 months or so I take my car off of the road most winters and I also set the car on stands and disconnect the battery. Instead of changing the oil though I normally remove the engine, replace the turbo, drivetrain, fuel system, engine manaagement and replace most of the other major components too. Doesn't everyone?
Guest CRAIG D Posted November 28, 2008 Posted November 28, 2008 I take my car off of the road most winters and I also set the car on stands and disconnect the battery. Instead of changing the oil though I normally remove the engine, replace the turbo, drivetrain, fuel system, engine manaagement and replace most of the other major components too. Doesn't everyone?
JohnSt Posted November 28, 2008 Posted November 28, 2008 I take my car off of the road most winters and I also set the car on stands and disconnect the battery. Instead of changing the oil though I normally remove the engine, replace the turbo, drivetrain, fuel system, engine manaagement and replace most of the other major components too. Doesn't everyone? Aye, but one complete cycle for you follows Leap Years !!!!
corsa Posted November 29, 2008 Posted November 29, 2008 as above and buy a optimate trickle charger to keep the battery tiptop Came out this morning and the scoob battery was deed, had to jump it. Time for you chaps to point me in the direction of a trickle charger that is safe to leave connected to the car in the garage whilst i am at work etc? Davie
dipsy Posted November 29, 2008 Posted November 29, 2008 Machine Mart sell one .I use a booster pack when the battery is flat in mine don't have power in my garage
paul555sti Posted November 29, 2008 Posted November 29, 2008 I use this one. http://www.theultimatefinish.co.uk/Store/P...x?ProductId=104
rallye6 Posted November 29, 2008 Posted November 29, 2008 my car sits in the garage for months at a time. I use the draper trickle charger ( can be purchased from halfords for £ 23.00 ) and its on day and night with no problems. Brian
wrxmania Posted November 30, 2008 Posted November 30, 2008 I take my car off of the road most winters and I also set the car on stands and disconnect the battery. Instead of changing the oil though I normally remove the engine, replace the turbo, drivetrain, fuel system, engine manaagement and replace most of the other major components too. Doesn't everyone? That might not be far from the truth!
thewelsho Posted November 30, 2008 Posted November 30, 2008 Hello folks!Hope your all well. The Scoob is goin into the garage this wknd for the winter and i was wondering if theres any tips or important points to be aware of when putting the car away for 6 months or so Any help much appreciated! Yeah, DON'T!
paul555sti Posted December 1, 2008 Posted December 1, 2008 Why!? Cal last year i sorn'd mines for 4 or 5 months but to be honest it just sat in the garage on the battery conditioner. I would start it at weekends and let it run for a while. There were days though when it was dry and sunny that i could have been out enjoying it. This year i taxed it for the year so its there ready when i want to use it.
colzo Posted December 1, 2008 Posted December 1, 2008 I use this one.http://www.theultimatefinish.co.uk/Store/P...x?ProductId=104 I have the CTEK charger too. Safe for long term use and also does motorbikes.
