scoobie virgin Posted April 3, 2008 Posted April 3, 2008 Hi, First of all hi to everyone as im a newbie. I bought a 99 STI on Monday and managed to cause some damage tonight coming off a round about hit limiter in second went for 3rd and car juddered, revs dropped like a brick, engine check light came on, now car wont idle and runs like a bag of nails. Any advice or help would be appreciated. Cheers
st3ph3n Posted April 3, 2008 Posted April 3, 2008 Checked all the hoses? Might have popped something if you've overboosted. Is the car mapped to UK petrol? Run on v-power or another premium product?
craigy Posted April 3, 2008 Posted April 3, 2008 Hi,First of all hi to everyone as im a newbie. I bought a 99 STI on Monday and managed to cause some damage tonight coming off a round about hit limiter in second went for 3rd and car juddered, revs dropped like a brick, engine check light came on, now car wont idle and runs like a bag of nails. Any advice or help would be appreciated. Cheers first of all welcome to sidc, i gather you gave the car a real good look over before buying it as its not always adviseable to give it the beans without noing a great deal about it? however this site iput up should give you all the answers youneed, your car has a on bord diagnostic check under your drivers console http://www.saxonfields.freeserve.co.uk/Sco...Diag%20Page.htm hope this helps
scoobie virgin Posted April 3, 2008 Author Posted April 3, 2008 Checked all the hoses? Might have popped something if you've overboosted.Is the car mapped to UK petrol? Run on v-power or another premium product? Yes checked hoses as much as i can see, I was just out of petrol station always use v-power. Hose was my first thought but cant see anything obvious (but when is it ever) Cheers
scoobie virgin Posted April 3, 2008 Author Posted April 3, 2008 first of all welcome to sidc, i gather you gave the car a real good look over before buying it as its not always adviseable to give it the beans without noing a great deal about it? however this site iput up should give you all the answers youneed, your car has a on bord diagnostic check under your drivers console http://www.saxonfields.freeserve.co.uk/Sco...Diag%20Page.htm hope this helps Car was running sweet as till 3 hours ago, not a sign of smoke not a rattle anything that would suggest it was abused. I did try to decipher the code to no avail, but it was flashing lots!! Cheers again
craigy Posted April 3, 2008 Posted April 3, 2008 Car was running sweet as till 3 hours ago, not a sign of smoke not a rattle anything that would suggest it was abused.I did try to decipher the code to no avail, but it was flashing lots!! Cheers again ok mate you need to study this web page to learn the codes it took me a while, this could be your maf, if thats the case the flash code would appear a bit like this long long short short short long = 10 short = 1 this code exsample = 23 the codes are read by connecting the black connector you can reset the code by doing the green connectors but will only wipe the codes till next time, wont solve the problem untill the nececerys are replaced/fixed cheers craigy
scoobie virgin Posted April 3, 2008 Author Posted April 3, 2008 ok mate you need to study this web page to learn the codes it took me a while, this could be your maf, if thats the case the flash code would appear a bit like thislong long short short short long = 10 short = 1 this code exsample = 23 the codes are read by connecting the black connector you can reset the code by doing the green connectors but will only wipe the codes till next time, wont solve the problem untill the nececerys are replaced/fixed cheers craigy Is it possible to get car connected to a fault reader for easier diagnosis? Flash sequence seemed a lot more than this mate but couldn't get my head around the it maybe tomorrow when a bit less pissed off i will get it better. Cheers
craigy Posted April 3, 2008 Posted April 3, 2008 as long as you no that a long blink is 10 and a short one is one, then you can cross refrence the code to the link i put up as for other diagnostics this is the cheapest option lol good luck dude,
scoobie virgin Posted April 3, 2008 Author Posted April 3, 2008 as long as you no that a long blink is 10 and a short one is one, then you can cross refrence the code to the link i put upas for other diagnostics this is the cheapest option lol good luck dude, Cheers everyone for their help, will let you know how i get on.
Scoobtastic Posted April 3, 2008 Posted April 3, 2008 sounds like the ECU has gone into safe mode... what you seem to have experianced is fuel cut or over boost....... take it back to where you got it if its got a warentee n let them sort it.....
scoobie virgin Posted April 3, 2008 Author Posted April 3, 2008 sounds like the ECU has gone into safe mode...what you seem to have experianced is fuel cut or over boost....... take it back to where you got it if its got a warentee n let them sort it..... bought it private so dont have any
Scoobtastic Posted April 3, 2008 Posted April 3, 2008 ar5e......main dealer it is then bud.....just to be safe....
scoobie virgin Posted April 3, 2008 Author Posted April 3, 2008 ar5e......main dealer it is then bud.....just to be safe.... just the thought of it sounds expensive!!! Will try again tomorrow to read the codes again or reset ECU to c if this works
nanaki Posted April 3, 2008 Posted April 3, 2008 might want to post where about you stay mate that way people will know if there close enough to offer assistance. It sounds like your car has gone into limp home mode. The car will appear to idol fine whoever if you try and give it beans and hit boost you will feel like someone has just put a brick wall in front of you. this is supposed to happen to protect the car. no higher than 2500 rpm till you get the code worked out. and the maf in the 99/00 cars is an extremly common fault due to its design. i'm on my 3rd in 18 months (fitted the new one earlier tonight) you could try resetting the ecu and then take it a drive. if the cel comes back on then get it to a dealer or see if anyone near you can help you read the fault code.
jd Posted April 4, 2008 Posted April 4, 2008 just readin this, 1st post says car will NOT idle and runs like a bag of nails. if ecu went into safe mode would still idle and drive, just have no guts. sounds like it could be expensive, did you let the car warm up before flooring it?
emoe Posted April 4, 2008 Posted April 4, 2008 just readin this, 1st post says car will NOT idle and runs like a bag of nails.if ecu went into safe mode would still idle and drive, just have no guts. sounds like it could be expensive, did you let the car warm up before flooring it? would deffo say something mechanical in the engine rather than boost pipes off. Someone else posted today about a mech fault!
superstar_tradesman Posted April 4, 2008 Posted April 4, 2008 where abouts are you fella, i'm in the falkirk area if you're anywhere near I'd be happy to have a look for you.
emoe Posted April 4, 2008 Posted April 4, 2008 Sorry mate, i am south england. Surely theres some places up there that will look for you?
scoobie virgin Posted April 4, 2008 Author Posted April 4, 2008 where abouts are you fella, i'm in the falkirk area if you're anywhere near I'd be happy to have a look for you. Hi, Im in kilmarnock, not very close to you im afraid but cheers for the offer if anyone closer has a clue what it might be i would appreciate any help, im just in from work so going to try and read the fault code again now ive calmed down a little, feel free to give me a call on 07708549428. Cheers Martin
scoobie virgin Posted April 4, 2008 Author Posted April 4, 2008 just readin this, 1st post says car will NOT idle and runs like a bag of nails.if ecu went into safe mode would still idle and drive, just have no guts. sounds like it could be expensive, did you let the car warm up before flooring it? Yes car was running for about 20 mins before giving it some welly
ormiboy Posted April 4, 2008 Posted April 4, 2008 Yes car was running for about 20 mins before giving it some welly Id reset the ecu to start with. if its the maf then the code will more than likely come back i would think. My car did something odd like this once, afterwards it would not idle well at all. Turned out the idle control valve had stuck for a bit. After pulling over and turning the car off and then on again it ran rough then cleared. The stored code was ICV. Is it worth giving the ICV a wee light carress with something?. i.e tap it with yer knuckle. Best of luck. Willie
scoobie virgin Posted April 4, 2008 Author Posted April 4, 2008 Yes car was running for about 20 mins before giving it some welly A big thanks 2 all its fixed was MAF £95 but who cares itwas worth it!!!!!
superstar_tradesman Posted April 4, 2008 Posted April 4, 2008 A big thanks 2 allits fixed was MAF £95 but who cares itwas worth it!!!!! That's cheap for a new MAF, mine was nearly £200
thewelsho Posted April 4, 2008 Posted April 4, 2008 A big thanks 2 allits fixed was MAF £95 but who cares itwas worth it!!!!! Glad to hear it was nothing serious mate.
