gazza_howard Posted September 11, 2007 Share Posted September 11, 2007 Can anyone help. I've got the optional extra Subaru cat 1 alarm fitted to my 2002 WRX and I keep getting a lot of false activations especially at night, typical. There seems to be no pattern to the activations and no obvious causes. My local dealer has checked it but can find nothing wrong. Has anyone else had a similar problem and found a cure??? Link to comment
CHRIS333UK Posted September 11, 2007 Share Posted September 11, 2007 Can anyone help. I've got the optional extra Subaru cat 1 alarm fitted to my 2002 WRX and I keep getting a lot of false activations especially at night, typical. There seems to be no pattern to the activations and no obvious causes. My local dealer has checked it but can find nothing wrong.Has anyone else had a similar problem and found a cure??? check all your windows are closed n ya boot is shut, what i kept doing was lifting the boot catch at the petrol station by mistake n not noticeing till the alarm went off later at night to warn me that the boot was unlocked,or try turning the interior light to the permanantly off mark,or it might be the batteries in the key fob that are low n need changeing,hope this helps mate,or run round the block too make sure no ones got a scanner going on ya car, SLEEP WELL, Link to comment
billy the fish Posted September 11, 2007 Share Posted September 11, 2007 check all your windows are closed n ya boot is shut, what i kept doing was lifting the boot catch at the petrol station by mistake n not noticeing till the alarm went off later at night to warn me that the boot was unlocked,or try turning the interior light to the permanantly off mark,or it might be the batteries in the key fob that are low n need changeing,hope this helps mate,or run round the block too make sure no ones got a scanner going on ya car, SLEEP WELL, if its the sigma mine started like this (only going off in the night) i replaced the bonnet catch which lasted a month or so then i realised with the help of "sigma sam" that when the alarm was going off the indicators werent flashing so the siren on its own was going off powerd by its own internal battery have a look see if the indicators flash when it alarms or just the siren on its own Link to comment
Barmybadger Posted September 12, 2007 Share Posted September 12, 2007 Can anyone help. I've got the optional extra Subaru cat 1 alarm fitted to my 2002 WRX and I keep getting a lot of false activations especially at night, typical. There seems to be no pattern to the activations and no obvious causes. My local dealer has checked it but can find nothing wrong.Has anyone else had a similar problem and found a cure??? Might sound silly but check there are no spiders in the car Link to comment
twofourdonkey Posted September 13, 2007 Share Posted September 13, 2007 Can you switch the internal sensors off? Mine goes off when it gets cold, and its seems to be the internal sensors measuring a pressure drop. Link to comment
gazza_howard Posted September 13, 2007 Author Share Posted September 13, 2007 Can you switch the internal sensors off? Mine goes off when it gets cold, and its seems to be the internal sensors measuring a pressure drop. Cheers I'll try that have to read the book first though see how to do it. Link to comment
Sigma Sam Posted September 14, 2007 Share Posted September 14, 2007 Can anyone help. I've got the optional extra Subaru cat 1 alarm fitted to my 2002 WRX and I keep getting a lot of false activations especially at night, typical. There seems to be no pattern to the activations and no obvious causes. My local dealer has checked it but can find nothing wrong.Has anyone else had a similar problem and found a cure??? The cause is likely to be one of 2 things, either: i) A fauly switch or bonnet switch out of adjustment or ii) The Ultrasonic settings being too sensitive Provided the system hasn't been triggered since the last "false" alarm then the easiest way to do this is to enter the following sequence into the keypad and then watch the status LED located to the left of the clock on the 02 model - count the LED flashes to confirm the circuit that caused the last trigger: - Arm and then Disarm the system using a working Radio Key. - Within 30 seconds of disarming, type into the keypad- *17856*38# - The alarm system's statusdash board LED will flash a number of times corresponding to the last triggered circuit 1= Ignition Detection 2= Door Switch 4= Boot Switch 8= Bonnet Switch 16= Ultrasonics When using the keypad always observe the following points: - The PIN number or programming sequence should not be entered too quickly or too slowly - when a digit has been pressed the small LED built into the keypad will illuminate briefly as confirmation and only then should the next digit be entered. - If an incorrect digit is pressed or the delay between entering digits exceeds10 seconds, then the LED above the keypad will flash rapidly and the PIN attempt should be abborted and started again after 30 seconds. - Due to the small size of the keypad some users may find a rubber tipped pencil easier to use. DO NOT use the sharp tip of a ball point pen etc, or press excessively ###### the keypad as this will only damage the membrane and cause a digit to remain pressed, causing a continual incorrect PIN. - The keypad allows only THREE PIN attempts (or an unrecognised sequence of 12 characters) and then will "Lock Up" if an incorrect number is entered a third time. This is a security feature to prevent random PIN attempts disarming the system. If this indicates that the bonnet switch is the cause, then the bonnet switch bracket should be bent upward. To test the adjustment, without releasing the bonnet try to lift the bonnet near the switch - when adjusted correctly attempting to lift a latched bonnet should not cause the siren to sound. If the ultrasonic sensors are shown to be the cause, then these can be adjusted. ideally these should be set to the standard settings using the keypad as follows: Adjusting the Ultrasonic Sensitivity Threshold: - Arm then disarm the system - Enter *17856*20*55# (in the above 55 is the Sensitivity Threshold Value) Adjusting the Disturbance Count: - Arm then disarm the system - Enter *17856*21*10# (in the above 10 is the Disturbance Count Value) Testing for the Correct Ultrasonic Settings: 1. Close all doors, tailgate/boot, bonnet, sunroof & windows. Standing close to the vehicle, in a position where the LED can still be seen, press the vehicle’s Remote Control to Arm the system in the normal way and observe the LED: • Initially, during the Settle Time (15 seconds at default), it will display short, dim flashes. • During the Ultrasonic Threshold Time (15 seconds at default), it will display long, bright, flashes. Ensure no movement is detected in this period, if it is, this will be indicated by the LED illuminating constantly for 1 second during its flash sequence • When fully armed the LED will dim slightly and display a short flash every 1 second 2. Now, with the security system fully armed, strike the centre of the vehicle’s door glass once firmly with the side of your hand and observe the LED. When striking the glass the status LED should illuminate constantly for 1 second, but the alarm should not trigger. Working around the vehicle, repeat this process on all the vehicle’s glass. Ideally, striking all the vehicles large glazed areas should illuminate the LED constantly for 1 second, however, due to variations in the fixing and thickness of the glass adjustments should only be based on the findings from the front side windows: • If the system triggers with one firm strike of the glass, the value of the Ultrasonic Sensitivity Threshold is too low, and the system could be prone to false alarms. The Ultrasonic Sensitivity Threshold should be increased from its current setting. Try increasing the value in increments of 5 from the original setting of 55 and repeat the test. • If, despite a firm strike on the front side glass, the LED does not illuminate constantly for 1 second, the Ultrasonic Sensitivity Threshold is too high and the Ultrasonic Sensitivity Threshold Value should be reduced from its current setting. Try decreasing the setting in increments of 5 from the original setting of 55 and repeat the test. 3. Once the Ultrasonic Sensitivity Threshold has been correctly adjusted for the front side glass, repeat the test, but this time strike the glass firmly in quick succession 6 or 7 times. The LED will illuminate again with the first strike and on the 6th or 7th strike the alarm system should trigger. This indicates that the settings are correct. • If the system triggers after only 1 or 2 firm strikes of the glass, the value of the Disturbance Count is too low, and the system could be prone to false alarms. The Disturbance Count should be increased from its current setting. Try increasing the value in increments of 2 at first from the original setting of 10 repeat the test. • If, despite 6 or 7 firm strikes on the front side glass, the LED illuminates constantly, but the system does not trigger then the Disturbance Count is too high and the setting should be reduced from its current setting. Try decreasing the value in increments of 2 at first from the original setting of 10 and repeat the test. Hope that helps, SS Link to comment
gazza_howard Posted September 15, 2007 Author Share Posted September 15, 2007 The cause is likely to be one of 2 things, either:i) A fauly switch or bonnet switch out of adjustment or ii) The Ultrasonic settings being too sensitive Provided the system hasn't been triggered since the last "false" alarm then the easiest way to do this is to enter the following sequence into the keypad and then watch the status LED located to the left of the clock on the 02 model - count the LED flashes to confirm the circuit that caused the last trigger: - Arm and then Disarm the system using a working Radio Key. - Within 30 seconds of disarming, type into the keypad- *17856*38# - The alarm system's statusdash board LED will flash a number of times corresponding to the last triggered circuit 1= Ignition Detection 2= Door Switch 4= Boot Switch 8= Bonnet Switch 16= Ultrasonics When using the keypad always observe the following points: - The PIN number or programming sequence should not be entered too quickly or too slowly - when a digit has been pressed the small LED built into the keypad will illuminate briefly as confirmation and only then should the next digit be entered. - If an incorrect digit is pressed or the delay between entering digits exceeds10 seconds, then the LED above the keypad will flash rapidly and the PIN attempt should be abborted and started again after 30 seconds. - Due to the small size of the keypad some users may find a rubber tipped pencil easier to use. DO NOT use the sharp tip of a ball point pen etc, or press excessively ###### the keypad as this will only damage the membrane and cause a digit to remain pressed, causing a continual incorrect PIN. - The keypad allows only THREE PIN attempts (or an unrecognised sequence of 12 characters) and then will "Lock Up" if an incorrect number is entered a third time. This is a security feature to prevent random PIN attempts disarming the system. If this indicates that the bonnet switch is the cause, then the bonnet switch bracket should be bent upward. To test the adjustment, without releasing the bonnet try to lift the bonnet near the switch - when adjusted correctly attempting to lift a latched bonnet should not cause the siren to sound. If the ultrasonic sensors are shown to be the cause, then these can be adjusted. ideally these should be set to the standard settings using the keypad as follows: Adjusting the Ultrasonic Sensitivity Threshold: - Arm then disarm the system - Enter *17856*20*55# (in the above 55 is the Sensitivity Threshold Value) Adjusting the Disturbance Count: - Arm then disarm the system - Enter *17856*21*10# (in the above 10 is the Disturbance Count Value) Testing for the Correct Ultrasonic Settings: 1. Close all doors, tailgate/boot, bonnet, sunroof & windows. Standing close to the vehicle, in a position where the LED can still be seen, press the vehicle’s Remote Control to Arm the system in the normal way and observe the LED: • Initially, during the Settle Time (15 seconds at default), it will display short, dim flashes. • During the Ultrasonic Threshold Time (15 seconds at default), it will display long, bright, flashes. Ensure no movement is detected in this period, if it is, this will be indicated by the LED illuminating constantly for 1 second during its flash sequence • When fully armed the LED will dim slightly and display a short flash every 1 second 2. Now, with the security system fully armed, strike the centre of the vehicle’s door glass once firmly with the side of your hand and observe the LED. When striking the glass the status LED should illuminate constantly for 1 second, but the alarm should not trigger. Working around the vehicle, repeat this process on all the vehicle’s glass. Ideally, striking all the vehicles large glazed areas should illuminate the LED constantly for 1 second, however, due to variations in the fixing and thickness of the glass adjustments should only be based on the findings from the front side windows: • If the system triggers with one firm strike of the glass, the value of the Ultrasonic Sensitivity Threshold is too low, and the system could be prone to false alarms. The Ultrasonic Sensitivity Threshold should be increased from its current setting. Try increasing the value in increments of 5 from the original setting of 55 and repeat the test. • If, despite a firm strike on the front side glass, the LED does not illuminate constantly for 1 second, the Ultrasonic Sensitivity Threshold is too high and the Ultrasonic Sensitivity Threshold Value should be reduced from its current setting. Try decreasing the setting in increments of 5 from the original setting of 55 and repeat the test. 3. Once the Ultrasonic Sensitivity Threshold has been correctly adjusted for the front side glass, repeat the test, but this time strike the glass firmly in quick succession 6 or 7 times. The LED will illuminate again with the first strike and on the 6th or 7th strike the alarm system should trigger. This indicates that the settings are correct. • If the system triggers after only 1 or 2 firm strikes of the glass, the value of the Disturbance Count is too low, and the system could be prone to false alarms. The Disturbance Count should be increased from its current setting. Try increasing the value in increments of 2 at first from the original setting of 10 repeat the test. • If, despite 6 or 7 firm strikes on the front side glass, the LED illuminates constantly, but the system does not trigger then the Disturbance Count is too high and the setting should be reduced from its current setting. Try decreasing the value in increments of 2 at first from the original setting of 10 and repeat the test. Hope that helps, SS Cheers mate. I'll have a play tomorrow and will look forward to some uninterupted sleep. Bet the neighbours will be pleased too. Link to comment
