terzo neil Posted November 1, 2009 Posted November 1, 2009 whats the plug gap for 6b plugs on a ver 4 turbo cheers Neil
wilky Posted November 4, 2009 Posted November 4, 2009 whats the plug gap for 6b plugs on a ver 4 turbocheers Neil .65 worked for me Neil.
paulcoleman Posted November 4, 2009 Posted November 4, 2009 Sorry to hijack, but does anyone know the gaps for a '00 classic, non turbo model. It's the only thing I haven't checked yet since I bought it. Cheers Paul
terzo neil Posted November 4, 2009 Author Posted November 4, 2009 plulled out the plugs tonight and they are, fitted new coil leads still got my misfire and rough running thank god it was dark the coil pack on the inlet is arcing out to inlet manifold so another coilpack is required, hopefully the one i am picking up soon should cure my problem
terzo neil Posted November 6, 2009 Author Posted November 6, 2009 got another coilpack... big thanks to John St back to full power and run ning like a dream
john_stevenson2 Posted November 7, 2009 Posted November 7, 2009 got another coilpack... big thanks to John St back to full power and run ning like a dream Wait till you see the bill !!!
Jazmac Posted November 14, 2009 Posted November 14, 2009 howday all dont know what a version 4 is in year wise but my manual for a 2000uk turbo Sreg says the plug gaps should be 1.0 - 1.1mm on 6B's, thats what i have them set at thought it was a tad wide myself visualy looking at them, the does car has a minor splutter approx 3 - 3.5k rpm when cruisin at 30ish do you fellas thinks its due to the plug gap if the recommendation is 0.65mm on here?????
terzo neil Posted November 14, 2009 Author Posted November 14, 2009 mines are at 0.65mm and run 1.4 bar of boost in the mid range cured my misfire as well with new plugs, leads and another coil pack
Big 'D' Posted November 14, 2009 Posted November 14, 2009 howday alldont know what a version 4 is in year wise but my manual for a 2000uk turbo Sreg says the plug gaps should be 1.0 - 1.1mm on 6B's, thats what i have them set at thought it was a tad wide myself visualy looking at them, the does car has a minor splutter approx 3 - 3.5k rpm when cruisin at 30ish do you fellas thinks its due to the plug gap if the recommendation is 0.65mm on here????? The ver 4 is MY98 to MY99 (pre face 2nd lift), what manual have you got for the MY99 Turbo? The std Subaru OEM gapping for NGK PFR6B spark plugs is 0.7 to 0.8mm the 1.0 to 1.1mm gap I thought was for the N/A scoobs? Cheers Iain
