paddy247 Posted June 18, 2006 Posted June 18, 2006 Apparantly I just filled up with 100 ron optimax at the shell Garage near knockhill, was chating to the owner and she is sure that the latest delivery of fuel is the 100 ron stuff. she said she recieved a dvd and various other bits of litrature to do with the new fuel also this week. Cars was pulling well but im no human data monitor lol
ally-b Posted June 18, 2006 Posted June 18, 2006 http://forums.sidc.co.uk/forums/704100/ShowPost.aspx Remember where you heard it first [] [] Al.
the squiggle Posted June 18, 2006 Posted June 18, 2006 What price was the said fuel? What ECU you running in your car Paddy?
paddy247 Posted June 18, 2006 Author Posted June 18, 2006 Its was normal prices £1.02 per ltr The scoob runs what it brung from Japan
the squiggle Posted June 18, 2006 Posted June 18, 2006 Just what i thought, the Version 1 runs a pretty agressive map better suited to 100ron Japanese pump fuel What about a wee bitty test!!!! Reset your ECU and take her out for a run If possible, plug in a diagnostic machine a look up the Knock Correction to see what correction the ECU pulls across the map. ED-209, stays in Moodiesburn has the software if AWD does not have the OBD2 compatible software If it is 100ron of the same blend as Jpn then it will pull very little correction across the map Heres hoping
the squiggle Posted June 19, 2006 Posted June 19, 2006 Where is this shell garage? Near Powmill http://www.multimap.com/map/browse.cgi?cli...;multimap.y=242 Scale out on the map from there
paddy247 Posted June 19, 2006 Author Posted June 19, 2006 Cheers for the pointer there Grant, yeh ive got access to the tools for the job, the car normally runs on optimax and booster and has pretty much no correction, so it will be interesting to see how it goes with the 100 ron
the squiggle Posted June 19, 2006 Posted June 19, 2006 Hence your pretty rapid stdish car Paddy Would be a good test to try pure new Optimax from Shell without booster to see what a JDM STI ecu does Knock wise
