dipsy Posted July 4, 2005 Posted July 4, 2005 Would fitting oil catch tank stop the oil from the breather on crankcase to the intake its an my2000 turbo fulldecat ecutek2 exchange because i think this is causeing my boost problems .I have cleaned solenoid pipes before plus i checked breather pipes and cleaned the crankcase to intake was the worst so cleaned with carb cleaner ie i took pipe of to do this stuck pipe back on took for a drive did this lot couple of weekends ago perect held boost no fluctuation.But yesterday the boost problem came back i checked this same breather pipe oily again.I am wondering would fitting oil catch tank solve this any ideas please
WRC No 1 Posted July 5, 2005 Posted July 5, 2005 how is ur oil. if there is 2 much oil it can cause over boosting and oil in the pipe works. i had the same prob with my 97 uk turbo. on the pic where it got the 4QT is where the oil should be when cold hope this helps wullie
dougster Posted July 5, 2005 Posted July 5, 2005 Dipsy I have some reading on catch can/PCV systems if you want me to send it via PM?
the squiggle Posted July 5, 2005 Posted July 5, 2005 << Dipsy I have some reading on catch can/PVC systems if you want me to send it via PM? >> Dont want to be pedantic but it is PCV, which stands for Positive Crankcase Ventilation. This is the system that Subaru uses to replace the old crankcase gases with fresh air from the induction. Unless you are referring to replacement double glazing, in which case i apoligise. Grant
dougster Posted July 5, 2005 Posted July 5, 2005 I can do windows if required. Edited for being so silly.
sma01 Posted July 5, 2005 Posted July 5, 2005 Think this is something that would help, am sure Youngo (P1SUB) fitted one of these, try PM'ing him and he'll tell you for def mate
dipsy Posted July 5, 2005 Author Posted July 5, 2005 I read stuff regarding breather system on andy forrest web site. He writes that the crankcase breather can cauase these problems
WUZ Posted July 5, 2005 Posted July 5, 2005 Grant - the PCV allows the Crankcase oil vapours to be "sucked out" of the Crankcase and into the Inlet Manifold (on idle) but on boost this valve closes (otherwise you'll get 1.2 bar of boost pressure blowing out all the seals!). I would consider attaching the Crankcase breather with the Cam breathers to the Oil Catch Can. remember to blank off the PCV or fit a 2" peice of hose with a blank on it onto the PCV. Russell
dipsy Posted July 5, 2005 Author Posted July 5, 2005 Regards me fitting an oil catch tank i am taking the car in to awd to let them sort my boost problem i hope it gets sorted.I will ask about price for samco induction pipe because can see little cracks round breather pipe connections
