rapid clicking sound when keys turned?
If it sounds like someone letting rip with an Uzi under yer bonnet it might well be your battery. Was with mine. Wouldn't turn over.
An overnight charge sorted it until I got a new one - when I took the old one out half the cells were black face-icon-small-happy.gif
Neil
I'd say more likely the starter solenoid. Check the wiring isn't loose. Be careful turning it over though, if it's arcing you may fry some expensive electrics (The ECU).
Have you tried push (bump) starting it?
<< I'd say more likely the starter solenoid. Check the wiring isn't loose. Be careful turning it over though, if it's arcing you may fry some expensive electrics (The ECU).
Have you tried push (bump) starting it? >>
not tried jump starting it as im in a parking space facing uphil plus on my own.
Got shunted from behind on monday and it has slowly died since then.
Yip sounds like the battery is dead, mine done this a few times. Worth an overnight charge then you need to find out if anything is live that shouldn't be especially if you've been in an accident recently.
Yeah you were right guys! the battery was being drained by the boot light due to the boot being slightly open with the accident last Monday. The light is now disconnected and all is fine, well apart from the massive dent in the back of my baby.
