zeb Posted June 28, 2020 Share Posted June 28, 2020 HI THERE, changed battery 2 weeks ago, no problems car started went for a drive no issues. 2 weeks later car from fob not opening door, once key in ignition electrics come on but car not turning over. Any advice / help out there Link to comment
The Don Posted June 28, 2020 Share Posted June 28, 2020 Is the Battery you "changed" (or should that be charged ??) 2 weeks ago still upto the job?? Was it fully charged?? Link to comment
zeb Posted June 28, 2020 Author Share Posted June 28, 2020 battery should hold its charge but will charge it up to see if its a battery fault. Link to comment
t5nyw Posted July 6, 2020 Share Posted July 6, 2020 if not ran for 2 -3 weeks some security alarms/tracers etc can take a toll on even a healthy battery. Most still owered even if not subscribed. Common issue are old tracker units (fitted from new) back batteries are old and FUBAR causing heavier and constant load. i put an ammeter on my T25 a had 8 amps drain. found unit and battery red hot and melting. i know one guy found 2 trackers in his, 1 original and 1 aftr market fitted by one of the previous owners Tony Link to comment
zeb Posted July 7, 2020 Author Share Posted July 7, 2020 thank you for the information Link to comment
