mctwistuk Posted June 9, 2012 Posted June 9, 2012 When I slow down and come to a halt there is a clicking/knock noise from the rear. It isn't the brake pads as I have replaced these and copper slipped them good. Only happens when you cone to a complete stop and the car settles back if that makes sense. Any ideas what it could be? Cheers Chris
phil1967 Posted June 9, 2012 Posted June 9, 2012 Easy fix......don.t stop........ Sounds like your rear struts....
mctwistuk Posted June 9, 2012 Author Posted June 9, 2012 (edited) New struts were fitted when I bought the car a couple of months ago. Pads are defo seated properly. Edited June 9, 2012 by mctwistuk
killbill Posted June 10, 2012 Posted June 10, 2012 this happened on a car i bought, it was the shims not fitted that caused it .
lister100 Posted June 10, 2012 Posted June 10, 2012 I had the same problem. Just one rear pad started to click, really annoying. What i did was to swap the pad over as just one seemed to have a little free play but nothing wrong with it. It did the trick until i replaced pads.
mctwistuk Posted June 10, 2012 Author Posted June 10, 2012 Pads are brand new but will try reseating when I get a chance. Noise was there with previous pads in also
lister100 Posted June 23, 2012 Posted June 23, 2012 One other thing. It maybe the springs holding the pads down. If they are not tight enough it could lead to pad movement at stopping. Worth a look.
mctwistuk Posted June 24, 2012 Author Posted June 24, 2012 Yeah front and back but did this before fitting them and changing the pads why?
wrx kenny Posted June 24, 2012 Posted June 24, 2012 My brakes make an odd noise when braking was told it's the braided hoses flexing when pressure put on the pedal . Kenny
subarucraig Posted June 24, 2012 Posted June 24, 2012 I get a click from front pad but only when I reverse into space and apply brake !
