scoobykev Posted July 9, 2010 Posted July 9, 2010 I'm after a bit of advise on turning my scoob into a track car. I decided to sorn it a few weeks ago and have bought a van to run just now. What are the rules about putting a car on the track, does it need to be mot'd or insured? I don't intend going daft modding it to the max but figured my brakes would be the most important item, so will the standard 4 pots be up to the job? I've never been on a track day but really fancy trying this, just want to do it as cheaply as possible and see how it goes. Just wish i was ready to go so i could've done John's novice day tomorrow. Thanks Kev
gambler Posted July 9, 2010 Posted July 9, 2010 I started building a track car about 5 years ago. We are now doing our second year of time attack. So be carefull. It can be addictive! If you don't have an mot circuits will just scrutineer the car for you to make sure it's safe. The most important things are suspension and brakes. Get these right and it will be lots of fun. A pair of second hand coilovers and a geo setup should help things. Possibly some stiffer roll bars will help too. The standard brakes are not great but can be made better with decent pads and uprated fluid. If you have the Subaru 4 pots then it's well worth the money to upgrade to brembo's. Learn to drive the wheels off the car with the standard power and upgrade everything else before you go modding the engine. Although, a remap from andy Forrest is never a bad thing. This will make you a much better driver on the long run. It starts to get expensive when you start modding the engine and the supporting mods. If you need to know anything just pm me. I could go on forever on this subject but just on the iPhone Scott
scoobykev Posted July 10, 2010 Author Posted July 10, 2010 Cheers for that. After being out with Euan today at the track day i need to get myself sorted out soon. That was good fun even in the passanger seat
ciaranrb5 Posted July 10, 2010 Posted July 10, 2010 Your best bet is to probably just go on the track as is. You will soon realise what you need Best place to start is probably to make the car as light as possible removing spare wheel and door cards, stereos, speakers and so on. Im building my car with the logic that double the standard power with all the best of suspension and brakes is the way forward. Also fitting a cage incase it all goes wrong which is hopefully won't
BalliSTIc Posted July 10, 2010 Posted July 10, 2010 You're not short on power anyways Kev. Just track it as is. She handles pretty well the way you have her.
scoobykev Posted July 10, 2010 Author Posted July 10, 2010 You're not short on power anyways Kev. Sshh Looks like i'll just strip some bits off stick the harness in and get it on a trailer down to knockhill sometime
TrackScotland Posted July 12, 2010 Posted July 12, 2010 (edited) as said above.... brakes and susp, then lightness .... once you have hindered by lack of power sort out the engine. Too many folk do the opposite and are hindered by too much power Edited July 12, 2010 by TrackScotland
p1ggm Posted July 12, 2010 Posted July 12, 2010 so far i have spent nothing in the way of mods for mine, its still even got the 2 pots on it, gonna get it road legal(just) run it about a few weeks then track it, see how it goes before spending money.
ciaranrb5 Posted July 12, 2010 Posted July 12, 2010 as said above....brakes and susp, then lightness .... once you have hindered by lack of power sort out the engine. Too many folk do the opposite and are hindered by too much power To much power is easily sorted it's called multiple maps
Big Daz Posted July 12, 2010 Posted July 12, 2010 What are the rules about putting a car on the track, does it need to be mot'd or insured? Kev, neither of mine were MOT'd, just of a good standard and safe. As said above, lightness is the key, loose EVERYTHING thats not essential and then loose some more ... If you need any help just give me a shout, happy to help with some spannering / unbolting Daz
scoobykev Posted July 12, 2010 Author Posted July 12, 2010 If you need any help just give me a shout, happy to help with some spannering / unbolting Daz Now you know i'm gonna hold you to that mate. I've got a fully loaded toolbox and not a clue how to use it Cheers for the help folks
p1ggm Posted July 13, 2010 Posted July 13, 2010 kev all you need is a 12, 14, 17 and 19 mm and a couple screwdrivers, subarus are easy to rip apart, i'm in if your needing help
TrackScotland Posted July 13, 2010 Posted July 13, 2010 To much power is easily sorted it's called multiple maps multiple maps are all very well... but they dont really change much if you have a big (more laggy) turbo and cams for example. I only use multiple maps for different fuels.
scoobykev Posted July 13, 2010 Author Posted July 13, 2010 Never had my car mapped, it's alway been the agricultural way. Fuel cut defender and screw up the boost. Never had a bit of bother. It has standard and high boost of the controller though.
