ciaranrb5 Posted October 24, 2009 Posted October 24, 2009 Well last month I had to change the drivers side rear wheel bearing. It ended up being a nightmare to do as nothing would come apart. I have done about 500 miles since fitting it and yesterday it collapsed on the A90 which was fun. The last time the wheel bearing failed i could hear humming but this time nothing it just fell apart with a massive clunk. It was a blueprint bearing that was fitted. So why would it fail so quicly? do these need a bedding in period?
johnnyr6 Posted October 24, 2009 Posted October 24, 2009 2 things that come to mind are dodgy bearing or poor fitting which may have damaged the bearing. The humming is from the bearing having excessive wear but that wouldn.t have been the problem in only 500 miles. Not good though. Johnny
euan_r Posted October 24, 2009 Posted October 24, 2009 wow thats a short life. even with gorilla fitting techniques i would of expected a lot longer than that. was bearing changed using a press and did they change seals and circlip afterwards? if first bearing was gone and not noticed quick enough they damage the hub and new bearing wont sit right. lost count of how many subaru wheel bearings me and my folks have had replaced over the years.
ciaranrb5 Posted October 24, 2009 Author Posted October 24, 2009 No gorillas tactics used a proper press for pushing the old bearing out. Cleaned up the inside of the hub and pressed the old one back in. There was no damage to the inside of the hub. I can only guess it was faulty bearing. Oh iv done trackday since getting the new bearing suppose that may not have helped
StewartyBoy Posted October 24, 2009 Posted October 24, 2009 Trackday shouldnt have killed the bearing. Just sounds like a suspect part to me. Warranty!?
dipsy Posted October 24, 2009 Posted October 24, 2009 http://www.importcarparts.co.uk/parts_info...&searchKey= .This place is good for subaru parts and at good prices
ciaranrb5 Posted October 24, 2009 Author Posted October 24, 2009 http://www.importcarparts.co.uk/parts_info...&searchKey= .This place is good for subaru parts and at good prices Why is that so cheap? My last bearing was £105 I will say to D&A that it was just fitted but I have no receipt so could be lucky
b4z Posted October 24, 2009 Posted October 24, 2009 could be a fauly bearing try another one and if that fails a would be chnging the hub as it could have warpped
ciaranrb5 Posted October 27, 2009 Author Posted October 27, 2009 Ok new wheel bearing fitted. Will see how long it lasts. The old bearing had broken into a million bits
