b6jmy Posted April 23, 2009 Posted April 23, 2009 car in drive way cant use it as cant turn off my alarm remote central not working and no interior light .. so very sad checked all fuses ok has this ever hapened to anyone
StewartyBoy Posted April 23, 2009 Posted April 23, 2009 Will it tick over!? Can you not just jump start it?!
thewelsho Posted April 23, 2009 Posted April 23, 2009 car in drive way cant use it as cant turn off my alarm remote central not working and no interior light .. so very sad checked all fuses ok has this ever hapened to anyone Dead battery? I say that because on occasion when I have disconnected the battery to clear the ECU, the alarm goes off cosntantly and obvioulsy the central locking and interal light wont work.
b6jmy Posted April 23, 2009 Author Posted April 23, 2009 plenty ov power in battery think it must have somthing 2 do with alarm or central locking
paul555sti Posted April 23, 2009 Posted April 23, 2009 plenty ov power in battery think it must have somthing 2 do with alarm or central locking I would have thought the interior light would still work then? Have you tried jump leads on it just to rule out the battery?
colin_ross Posted April 23, 2009 Posted April 23, 2009 Yes I have heard of this before and when tested the battery was fine. It was ther connection to the battery that was at fault. Get a volt meter and check out the battery from the terminals and if thats ok then check it from the leads connected to it.
b6jmy Posted April 24, 2009 Author Posted April 24, 2009 got the car 2 start alarm gives one audibil bleep no central locking and no interior light or clock help me out on this please is thre a relay wich controls this
t1000arab Posted April 24, 2009 Posted April 24, 2009 I had a similar problem a while back. Took me ages to track down the fault. The negative battery terminal was loose . One of the first things I did was check the positive terminal but for some reason I didn't check the negative terminal...
b6jmy Posted April 24, 2009 Author Posted April 24, 2009 fixed thanks for all your help guys.... turned out i didnt know about the fuse box under bonnet ..
scoobysailor Posted April 24, 2009 Posted April 24, 2009 I had a similar problem a while back. Took me ages to track down the fault. The negative battery terminal was loose . One of the first things I did was check the positive terminal but for some reason I didn't check the negative terminal... I had the exact same problem a while back on my old blobeye......
