b4z Posted January 11, 2009 Posted January 11, 2009 hi guys after some advice . i have a uk 2000 turbo impreza. when the car is building up revs and boost the thing stops reving and hessitates and sometimes get a bit poping and banging no idea whats causing it any ideas or help would be great
thefastone Posted January 11, 2009 Posted January 11, 2009 You getting any fault codes? You know how to check? Also what mods you have done to the car? that will help the more technically minded amongst us to help ye!
thefastone Posted January 11, 2009 Posted January 11, 2009 To check fault codes on a Classic see the following links... http://www.scoobypedia.co.uk/index.php/Kno...ReadingECUCodes http://www.scoobypedia.co.uk/index.php/Kno...CodeDefinitions http://www.scoobypedia.co.uk/index.php/Knowledge/ECUReset Provided your car is standard that is, beyond that I'm no help...
scoobyseller555 Posted January 11, 2009 Posted January 11, 2009 coil packs,just had the same problem with mine,has the car fluctuating idle-would point to maf sensor. Gav
gus the bus Posted January 11, 2009 Posted January 11, 2009 Baz, Possibly a coil pack breaking down. Check all the leads for splits/breaks. Does it only happen when the car is cold? as the other option for that could be Lambda sensor failing. Just ma tuppence worth
gus the bus Posted January 11, 2009 Posted January 11, 2009 coil packs,just had the same problem with mine,has the car fluctuating idle-would point to maf sensor.Gav Beat me to it Gav
Big 'D' Posted January 11, 2009 Posted January 11, 2009 (edited) If you can, read the ECU codes as described earlier by Dale aka 'The Fast One', the car should tell you what is wrong with it Two of the most likely causes have been described already the coil pack and the o2/lambda sensor, if the check engine light comes on with this hesitation it could also be the knock sensor or the MAF sensor. Cheers Iain Edited January 11, 2009 by Big 'D'
thefastone Posted January 11, 2009 Posted January 11, 2009 Why do people insist on refering to me as "the fast one"...? I am a person and not an object...
b4z Posted January 11, 2009 Author Posted January 11, 2009 just changed the maf and a have individual coils will fault code read it and see what she says
thefastone Posted January 11, 2009 Posted January 11, 2009 Could STILL be the MAF, as they are so Fragile... I'm sure that I heard a while ago about a dealer that they got 2 new ones to fit and they were broken too...
Big 'D' Posted January 11, 2009 Posted January 11, 2009 Why do people insist on refering to me as "the fast one"...? I am a person and not an object... LOL a bit touchy mate, if I knew your name I would use it I am not an a*** Cheers Iain
Guest greegsy Posted January 11, 2009 Posted January 11, 2009 My old car - MY99 turbo had similar symptoms and it was the boost solenoid, removed and cleaned out with carb cleaner then refitted. 10 minute job and car ran sweet again after that. Possible cause maybe? Greegsy
Rossco_ Posted January 11, 2009 Posted January 11, 2009 Why do people insist on refering to me as "the fast one"...? I am a person and not an object... Clearly your celebrity status hasnt travelled that far DALE Maybe stick your actual name in your sig or have your username as your actual name? Wild i know!
Big 'D' Posted January 11, 2009 Posted January 11, 2009 Clearly your celebrity status hasnt travelled that far DALEMaybe stick your actual name in your sig or have your username as your actual name? Wild i know! I have modified my original post so that it now states you name Dale, I am sorry if I offended you in any way Cheers Iain
thefastone Posted January 11, 2009 Posted January 11, 2009 lol no, i just think that its funny, thats all... just the different ways that people write it, sometimes its not like your talking about a person... theres CERTAINLY no offence in any direction...
Big 'D' Posted January 11, 2009 Posted January 11, 2009 lol no, i just think that its funny, thats all... just the different ways that people write it, sometimes its not like your talking about a person...theres CERTAINLY no offence in any direction... Thats ok then, I didnt want to jump in repeating something that you had already put up in this post (the ecu fault reading bit) so I though it best to quote you instead Cheers Iain
b4z Posted January 12, 2009 Author Posted January 12, 2009 tonight i reset the ecu and took her for a spin came back with maf sensor fault. new one must be fault 2 so if anyone has a green label maf let me know or can point me in right direction. anyone know how much these are new?
superstar_tradesman Posted January 12, 2009 Posted January 12, 2009 tonight i reset the ecu and took her for a spin came back with maf sensor fault. new one must be fault 2 so if anyone has a green label maf let me know or can point me in right direction.anyone know how much these are new? Give charlie at Grieves a call.
scoobyseller555 Posted January 12, 2009 Posted January 12, 2009 01324 605100 £70 odd if i remember correctly
b4z Posted January 12, 2009 Author Posted January 12, 2009 01324 605100£70 odd if i remember correctly thank mate
b4z Posted January 13, 2009 Author Posted January 13, 2009 called today 250 quid for a new sensor someone help lol
ciaranrb5 Posted January 13, 2009 Posted January 13, 2009 called today 250 quid for a new sensor someone help lol Tell them you only want the sensor not the assembly included. The have quoted you for the sensor and the actual pipe it fits into.
bobbyc Posted January 13, 2009 Posted January 13, 2009 Last one I got at Hypertech for my 98 turbo was £65
scoobyseller555 Posted January 13, 2009 Posted January 13, 2009 £250 for 92-98 classics,£73 for 99-01 Gav
b4z Posted January 17, 2009 Author Posted January 17, 2009 Tell them you only want the sensor not the assembly included.The have quoted you for the sensor and the actual pipe it fits into. will ask the question mate
