mikeyb13 Posted October 11, 2008 Posted October 11, 2008 Changed the rear discs and pads on the Type R, and changed the piston seals. Been trying to bleed the brakes with little success. I have put 2 litres through the system now and it just doesnt seem to be getting any better. I am doing them in the right order, theres no sign of any air bubbles when i am bleeding them. The car has been left ovenight in the garage and there are no signs of leaks. The only thing I am doing different is using dot 5.1 but I dont see how they would be softer?!? Help please before I start breaking stuff Cheers All Mikey
scouk Posted October 11, 2008 Posted October 11, 2008 Dunno if it helps, but I recently did the brakes on my bugeye and the bleed order was: Front offside Rear nearside front nearside rear offside. I only replaced the front brakes and didn't even use 500ml of fluid to bring it up again! (I think the entire system is aroudn 1 litre.. (coudl be wrong)
J.C. Posted October 11, 2008 Posted October 11, 2008 I thought you bled the furthest from the servo first.
mikeyb13 Posted October 11, 2008 Author Posted October 11, 2008 Dunno if it helps, but I recently did the brakes on my bugeye and the bleed order was:Front offside Rear nearside front nearside rear offside. I only replaced the front brakes and didn't even use 500ml of fluid to bring it up again! (I think the entire system is aroudn 1 litre.. (coudl be wrong) According to the service manual Front right Rear left Front left Rear right I believe the system only holds 500ml
kookamunga Posted October 11, 2008 Posted October 11, 2008 if your going to change you fluid from dot 4 you will need to flush the whole system. but it you have already gone through 2 l it should be flushed by now. you don't have abs OR ARE U SURE YOU DON'T HAVE SOFTER SHOES ON YOUR FEET. soz man hope u get the resolve
