Double Zero Posted June 21, 2006 Posted June 21, 2006 Hi guys needing some info regarding my scooby its a november 00 wrx it has a fibre glass bonnet can anyone tell me if this is a standard fitment & btw i found the fusebox behind the imm keypad fuses are all fine checked the power supply to the clock and its fine so the clock must be goosed if anyone has any ifo on one for sale please let me know..... Cheers DZ............Drat & Double Drat....Mutleeeeeeeeeeeeey
RA Dunk Posted June 21, 2006 Posted June 21, 2006 i doubt fiberglass would be standard but i could be wrong
Double Zero Posted June 21, 2006 Author Posted June 21, 2006 Thats what i was thinking m8 its well light compared to Dtabbits classic bonnet he said the car felt much lighter than his when i gave a shot.
the squiggle Posted June 21, 2006 Posted June 21, 2006 Might be a JDM Alloy bonnet. My bonnet as fibreglass and floaty light
Double Zero Posted June 21, 2006 Author Posted June 21, 2006 Its defo fibreglass m8 i scraped a small piece under the bonnet just to make sure,floaty light just like your one.
st3ph3n Posted June 21, 2006 Posted June 21, 2006 Floaty light! Are we going to run with that then after my use about your wheels Grant? I'm liking it. Double Zero, does the bonnet flex and shimmy like a right bastart at speed on the motorway like the regular ones do? It wouldn't be the first time I've been bombing along the taxiway preparing for a wangan run and found myself pulling over just to check everything was safely fastenned down.
Double Zero Posted June 21, 2006 Author Posted June 21, 2006 No it seems pretty stable at high speed ,it did yesterday as i was giving it some on the way back from Aberdeen.
david_taylor Posted June 22, 2006 Posted June 22, 2006 Thats what i was thinking m8 its well light compared to Dtabbits classic bonnet he said the car felt much lighter than his when i gave a shot. I never said that you lying sod!! I said it felt slower and the brakes were shot at the front!
slo2 Posted June 22, 2006 Posted June 22, 2006 Floaty light! Are we going to run with that then after my use about your wheels Grant? I'm liking it. Double Zero, does the bonnet flex and shimmy like a right bastart at speed on the motorway like the regular ones do? It wouldn't be the first time I've been bombing along the taxiway preparing for a wangan run and found myself pulling over just to check everything was safely fastenned down. Is it advisable to fit bonnet pins ? as mine does the same and continually scares the carp out of me
