ROAR Posted June 9, 2006 Posted June 9, 2006 Any ideas on how to stop the exhaust heat sheilds vibrating when cold [8-)] I've tried turning the radio up but this doesnt stop it []
darryl_martin Posted June 9, 2006 Posted June 9, 2006 Had a car once where the heat shield rattled from about 2.5k to 3.5k revs, just as the turbo cut in. Thought things were going to be really expensive, then realised it was just the heat shield!!!! Went to local exhaust place and they took it off for me. Intended to refit a new one but never got round to it. Might just need tightening up, mine was only held on by two very flimsy strips of metal, one of which had rusted through, hence the vibration. I'd say first stop exhaust/tyre place.
ROAR Posted June 10, 2006 Author Posted June 10, 2006 Take them out - they won't rattle at all then.... i take it if i remove them ,then it wont have any detrimental effect to any thing else???
Pele Posted June 10, 2006 Posted June 10, 2006 No, a Subaru speasialist told me to take mine out & it wouldn't do any harm - just stops the rattle lol []
HOL Posted June 10, 2006 Posted June 10, 2006 Bring it round one weekend and Ill weld it back together, so you can bolt it back on. Assuming that you have all the bits??
XR-Wayne Posted June 10, 2006 Posted June 10, 2006 Im hopefully going to look into a Custom made Shield to put where the turbo is and also stop the heat getting to the brake and clutch Fluid
tony_cousins Posted June 10, 2006 Posted June 10, 2006 Take the sheilds off and get a decent wrap for the pipes, less weight and less heat into the engine bay too !!!![]
ROAR Posted June 12, 2006 Author Posted June 12, 2006 thanks for all you help and offers of help (HOL) will have a look to see if i can see the problem is when i get a bit of time thanks again all your all stars [A]
