bigdavie Posted May 18, 2006 Posted May 18, 2006 right i had a prob the other day and you guys correctly diagnosed a maf fault cheers !! today the problem is back the power is surging if you know what i mean ?? when you floor it its like im rolling the power on and off but i'm not ?? i dont think its the maf this time as the car is now idling properly ! any ideas folks ?? this is starting to worry me cheers
st3ph3n Posted May 18, 2006 Posted May 18, 2006 Bad batch of gogojuice perhaps? If you're at the meet tonight get some of the mad scientists to have a look.
bigdavie Posted May 18, 2006 Author Posted May 18, 2006 aye i'll maybe keek my heid in for a wee while and ask a few bods to have a look at her !!
colin_ross Posted May 18, 2006 Posted May 18, 2006 Could be a few things. Do you have a boost gauge and is the boost stable? It's quite common to fry the lamda sensor when the maf goes. Have you done an ecu reset to see if it throws up a cel?
AVI_8 Posted May 19, 2006 Posted May 19, 2006 Have you replaced the MAF yet? My car is doing the same thing boost comes on and off, apart from that it drives perfectly and idles very evenly. I was told that the problem sounded like a failing MAF. When I unplugged the MAF with the engine running the idle dropped a few hundred rpm and then recovered, if it was working ok i'm led to believe that it should have cut out by unplugging it. Im getting a new one asap but in the meantime driving off boost. So it would appear that they dont always idle unevenly with a fcked MAF
bigdavie Posted May 19, 2006 Author Posted May 19, 2006 yep replaced maf /dont have a boost gauge and i just disconnected the battery to reset the ecu ?? is that ok ??
colin_ross Posted May 19, 2006 Posted May 19, 2006 That's how I do mine, couple of hours should do it.
AVI_8 Posted May 19, 2006 Posted May 19, 2006 I'm sure i've read somewhere that the battery will have to be disconnected for several hours in order to reset the ecu. Apologies if i'm talking bollocks
bigdavie Posted May 19, 2006 Author Posted May 19, 2006 ahh !!!! i only let min rest for a few minutes lol !! can i get confirmation of this ??
AVI_8 Posted May 19, 2006 Posted May 19, 2006 Try a search on this site or scoobynet And theres a website called www.saxonfields.freeserve.co.uk, I'm sure theres a link on ecu resets there.
ross_mcewan Posted May 19, 2006 Posted May 19, 2006 A friend of mine had the same problem and had everything looked at and in the end it turned out he needed a new set of plug leads belive it or not!
bigdavie Posted May 20, 2006 Author Posted May 20, 2006 problem solved !!!! it was the boost solenoid needed cleaning !! exactly as ally b had suggested !cheers buddie !! took it down to greers and they told me the same as ally you cant top the 99 00 cars up to the brim with oil as it fudges the solenoid !! so a big thanks to ally and a big thanks to greers again !! brilliant !!!!
ally-b Posted May 20, 2006 Posted May 20, 2006 Thanks for the thanks Davie .[:$] I'm no expert , but I've owned a '99 and a '00 so I know most of the things to look out for with them [] I'm glad my diagnosis was correct and maybe saved you a few quid. Scottish-scoobies guys are generally a good bunch , and we all try to help each other out with the benefit of our own hard-earned lessons . We all know a little , which put together is a LOT of knowledge . Good to see you last night at the Glasgow meet and I hope we'll see you again at the meets [Y] ATB, Al.
bigdavie Posted May 20, 2006 Author Posted May 20, 2006 well tell you what if you're gonna be there then count me in al cos your a mine of info !! also very down to earth and .............. what did you have to eat ?? lol !! wish i could have stayed but as i said the mrs was left decorating while i was " galavanting !! " but am so glad the car is now boosting properly ! phew !!!
RA Dunk Posted May 20, 2006 Posted May 20, 2006 good to hear all is well m8... thats something off yer mind anyway nothing worse than knowing yer car aint running worth a f3ck and you dont know if its anything major or not
bigdavie Posted May 20, 2006 Author Posted May 20, 2006 christ tell me about it mate !! but you will be pleased to know i gave a 911 g plate a clean set of heels on the way home after i knew what was wrong lol !!
