S6ooby Posted July 20, 2003 Share Posted July 20, 2003 Hi all, I fitted air con to my uk turbo last weekend and now the idle is rough as buggery after we had the battery disconnected. Anyone got any ideas???? Its just very very lumpy... (the idle) Thanks in advance Link to comment
aircrest Posted July 20, 2003 Share Posted July 20, 2003 Got lots of idaes on that one.... Had same problem myself.........after using, righted itself.......can only imagine ecu is learning again........but had loads of horror stories and faulty "idle switches" on the way !!!! Time I found was the healer Link to comment
kipper Posted July 21, 2003 Share Posted July 21, 2003 I agree, i think the ecu is just learning the knock point etc after it reset when you took the batt off. should clear its self in time Link to comment
S6ooby Posted July 21, 2003 Author Share Posted July 21, 2003 Phew that's the answer i wanted!! Once again its "Brian to the rescue!!" Cheers guys will see if it resolves itself, it's in for servicing over the next couple of weeks so i will get them to check for eror codes. Saludos Andy C Link to comment
