Highlander68000 Posted July 20, 2003 Share Posted July 20, 2003 Can any one give me advice. I've got a 94 WRX and have just put a 95 WRX Type R Engine in. I'm running a Power FC ECU. I heard the engine running in the donor vehicle. The engines in and it won't run. When cranking over it seems to spark once and that's it. There is fuel going into the engine etc. I've checked the wiring loom and the only difference is two wires that go to the 5th Injector which are not connected to anything on the car side of the loom connecters. Can anybody give me advice as I've only got the workshop for the rest of today Thanks Link to comment
CustomScoobyIOM Posted July 21, 2003 Share Posted July 21, 2003 Sounds like you have the wrong wiring loom...... DO you have the Type R wiring loom or not as sods law thats what it is. Dunno on the Scooby but normally the 5th Injector is the cold start injector.... Link to comment
