oz *sti* Posted February 6, 2006 Posted February 6, 2006 Hi all, I'm thinking of getting an Apexi Power FC fitted to my sti V3 import at the mo it only has de-cat centre section afterburner b/b, larger fuel pump (and a dump valve, if that counts as a mod?!?). At the mo it is running around the 280ish mark maybe a couple more with the exhaust . My question is if I get the apexi fitted what sort of power gains could or would I expect to see, the way the car is set up just now? Thanks in advance [].
the squiggle Posted February 6, 2006 Posted February 6, 2006 With no more mods to the engine then power will be similer but the car will run about 100000000000 times safer on UK fuel Add an adjustable fuel pressure regulator and a decat downpipe, then a healthy gain will be noticed Grant
paul_honthy Posted February 7, 2006 Posted February 7, 2006 How you doing mate Ive got the STI3 myself and spoke to AndyF about the next step.What your going to do is what he strongly advised then allowing you a good basis for some futher tuning.
