billyboy Posted July 9, 2005 Posted July 9, 2005 Can somebody please tell me how to copy and paste.I need some computer lessons.
st3ph3n Posted July 9, 2005 Posted July 9, 2005 Drag your mouse over some text (assuming you want to copy text), then go to the edit menu and hit copy. OR, use the keyboard shortcut, which is holding down control and tapping c. To paste just put the mouse where you want the text to go and chose paste from the edit menu, or use the keyboard shortcut of control and v. Control and x = cut (which copies the text and then removes it from the screen). Doing pictures is much the same really, but obviously not every application supports copying and pasting pictures.
chrissy Posted July 9, 2005 Posted July 9, 2005 either that or drag the mouse over some text and right click yer mouse, then go to copy. to paste put the curser where u want the text and right click the mouse again and go to paste
