Oil Catch Tanks
Ok so who has one fitted? Is it a must for non modded car that isn't a a daily runner? Should it be 2 port or 3 port? Baffled or not? Are they easy to fit?
Chris
i fitted a two port to mine as well. I did it to stop any crud getting into intercooler and reducing air/fuel mix quality.
The standard system is setup to allow air to circulate through rocker covers and out crank breather, then back into air intake or manifold depending on engine vacum/boost.
i removed all oem breathers, bunged manifold and inlet pipe ports, put mini filters on rockers and fed crank breather to catch can.
my cars fairly standard just now but looking to make a few small changes in near future. Do a lot of work on my car and every time i had intercooler off was annoyed at seeing a bit of oil in pipes. The seals on my old vf28 didnt like 1.5 bar as it turned out but all squeeky clean now.
  • 2 weeks later...
