woodywrx Posted November 12, 2010 Posted November 12, 2010 may have decided to keep the impreza and therefore does anyone have any tgv's available? i need 1 for my bugeye as my mechanic was nice enough to snap it. pic below of what i need. its the 1 that is by the turbo solenoidon back of inlet manifold
j-k Posted November 21, 2010 Posted November 21, 2010 i have a set of TGV's complete if you are still looking? jon
j-k Posted November 28, 2010 Posted November 28, 2010 Dont really know what they are worth to be honest? Make me an offer? I am based in rainham if you want to collect? jon
j-k Posted December 19, 2010 Posted December 19, 2010 Good to meet you Sam.... Hope you get your car sorted. jon
woodywrx Posted January 6, 2011 Author Posted January 6, 2011 yeh nice to meet you too, thanks for the bits, car now running alryt. just want to pick your brains, its overheating and i have bled the system but it seems to have a sort of white foam forming in the header tank.
stum450n Posted January 6, 2011 Posted January 6, 2011 yeh nice to meet you too, thanks for the bits, car now running alryt. just want to pick your brains, its overheating and i have bled the system but it seems to have a sort of white foam forming in the header tank. Is the coolant a nice clean coolant colour or does it look contaminated and dirty?
woodywrx Posted January 9, 2011 Author Posted January 9, 2011 (edited) Is the coolant a nice clean coolant colour or does it look contaminated and dirty? it still has a bit of 'fudge' colour to it, but the head gaskets have just been replaced with skim and pressure test. i have to try bleed the coolant system every time i want to go anywhere as the foam just builds up again? ive been looking online and think the system might just need to be flushed several times. what do you think?? and if it does, is it worth using a radflush or just clean water? Edited January 9, 2011 by bugeyewrx
stum450n Posted January 9, 2011 Posted January 9, 2011 it still has a bit of 'fudge' colour to it, but the head gaskets have just been replaced with skim and pressure test. i have to try bleed the coolant system every time i want to go anywhere as the foam just builds up again? ive been looking online and think the system might just need to be flushed several times. what do you think?? and if it does, is it worth using a radflush or just clean water? Well if the head gaskets have been done then yeah, might be worth flushing the system, just run it through with a hose. I would get a gas check done on the existing coolant first though to be on the safe side. Check the thermostat in a cup of hot water as well, that may explain the overheating.
woodywrx Posted January 10, 2011 Author Posted January 10, 2011 ok il give it a go. Thermostat is a new 1 to. Had that replaced wen engine was rebuilt.
stum450n Posted January 10, 2011 Posted January 10, 2011 ok il give it a go. Thermostat is a new 1 to. Had that replaced wen engine was rebuilt. Just to reiterate - get a gas check on the coolant before you flush it - for the time/cost it's better to be safe than sorry eh!
woodywrx Posted January 10, 2011 Author Posted January 10, 2011 ok thanks. Wher can i get that dne? Any garage?
stum450n Posted January 10, 2011 Posted January 10, 2011 ok thanks. Wher can i get that dne? Any garage? Yup
