Project
HISTORY .
i bought my 2002 bugeye in 2004 , i seen richard burns driving one on the rally stages and decided there and then i wanted one , but due to other cars and commitments it had to wait . the day came 06th february 2004 i picked the keys up to my wrx i think 8000 miles and owned by rbs previously, so driven by a total banker . once i picked it up other subaru owners kept flashing and waving , always returning the gesture. At that time i lived in lenzie i kept seeing this one impreza all the time waving and flashing it eventually turned out to be HI-JAC who told me all about the club so i joined .i never got to any meets as was to busy with work , but eventually re joined about two years a go the sidc . only mods to the car at that stage were eibach springs . To be honest i knew nothing about modding an impreza the club has well and truly changed that . my car wasnt an sti nor did i want an sti look a like so i opted for an individual looking wrx , so along came a high level boot spolier , 18" team dynamics alloys , colour coded side skirts, front splitter , whiteline arb droplinks , bc coilovers, . Externaly the car is how i want it although got a zun grill front mesh kit to go on and fog light covers also waiting at home .
ENGINE
As a few of you know i took my car up to crail and shagged the bottom end ,there was a slight rattle which never got any worse even after glasgow and lanark runs and this years highland fling , anyway bought a second hand blob 2.0 block with 18000 miles it was put in ran for a couple of days then the crank went solid . I had bought mods to upgrade the power including 550 pinks , sti tmic , vf35 turbo and some toys forge dump valve k&n cone filter front and rear brembos etc , all a waste of time after buying a fecked block of piston heads , so basically had to start again and re think the options , new impreza or crack on wae the bug , crack on wae the bug was the outcome .
so today purchased a brand new 2.5 block hopefully should be delivered soon then i can get cracking and get this car back on the road , also been thinking about eventual power i now want to get into the 400s so bigger turbo injectors will be bought ( see you sat phil) .
forged bits and pieces will be bought this week as well , i will update the post as things progress and get pics as well . oh i cant wait
ALL ADVICE AND SUGGESTIONS WILL BE GLADLY ACCEPTED i want to get this car right and you lot are a mountain of knowledge B)
kenny
kenny
Do all the hard work on the engine then put it in mine :lol:
Best of luck with this build Kenny, lookin' forward to seeing this finished and on the road - post loads of pics.
Fraser
Will be good to see how it all prgresses for you Kenny. Will be quite a difference going from near standard to what you'll roughly finish with - potentially almost twice as many horses !! :lol:
As far as advice, I'd be no use B) . Suppose all I could say is the obvious of just do your homework, take your time and spend your money backed up with knowledge.
Bring on the monsta bug!! Looking forward to hearing how this develops m8. Seeing your bug a few times, especially when you got the bc's on was a wee inspiration to myself. Might even see you burbling by when your working down this neck of the woods. I had the zunsport front grilles put on on a few weeks back, really makes a difference I think. Will need to update my thread as well now.
All the best with it! B)
kenny were did you buy your block from
bought the block from a company in colorado called heubergermotorsports ,i spoke to the guy that owns it way back at the beginning of the year . I did find a company that would supply a bit cheaper gruppe motorsport but in over a month of sending e mails and asking questions , the only reply i got back was what was my postal address not good in my book so went to the above company , hopefully the block should be getting shipped next wednesday at latest.
Im now back home so can get on wae buying the internals wiseco is probably where ill end up , as money is tight for this car it wont be a no expense spared build , i aint in that league so slowly but surely as i need to buy a diesel for work soon, whats peoples thoughts on the WISECO forged internals before i go of purchasing as the original post said i will take on all advice and digest
thanks
kenny
Edited by wrx kenny
  • 2 weeks later...
good news the new block is sat in fed ex cumbernauld depot so should get delivered on tuesday hopefully.then get the car back down to the gagage to get the work done , i have decided on the following internals which should arrive end of next week ... he says
eagle con rods
mahle pistons
acl bearing set
arp head studs
and other stuff which i cant remember some rcm goodies
i will post pics up as the work begins, although i have to rely on other people to do that as im away again
kenny
Good read there Kenny. Sorry I cant give you advice on what to do or how cos my knowledge is limited to basic stuff regarding mods. Nothing compared to what some of these guys are doing nowadays.
I guess youre going to get all the block, internals sorted out as the main project first.
Then think about the stuff like injectors, fuel pump, headers,zorst, new turbo, FMIC, filter/airflow, ECU.
I think my old STI was running high 300s, maybe low 400s and all I did was
Injectors
Headers (equal length or almost equal length)
Fuel pump
Oil pump
Decat
49G turbo (pretty laggy and had to be worked on boost)
FMIC
Remap
Hope this helps
Injectors
Fuel pump
Oil pump
Decat
FMIC
Remap
Hope this helps
i already have most of the mods in place been buying them over the last wee while , although some are getting changed, so far i have on the car
vf35 funds allowing change that to an md 321 t
550 pinks replacing with 650s (thanks to phil)
headers up pipe de cat
sports decat downpipe
decat center pipe
sti tmic
pfr7bs
walbro 255 fuel pump
k&n typhoon induction
probably more stuff but i cant remember just now , as ive said before i dont want big power i just want to keep up on the runs my 2.0 wrx mostly un modified couldnt cut it on the straights behind the sti,s i just got left behind so hopefully this will be rectified
kenny
good list of toys you have there ! Looks good. I remember getting mine all fitted then limping through to Edinburgh to see Andy for the map. Not worth the risk of doing anything else.
Drop links front and rear
Swaybar
Strut braces
Anti lift kit (didnt have)
Tein springs
Geometry again
The car will handle like its on rails
Edited by GUMBALL
Good to hear that your finally getting sorted Kenny, be nice to see you out & about again mate, look forward to reading about your progress :thumbup:
decat center pipe
sti tmic
pfr7bs
kenny
Hi Kenny the 321T on a forged 2.5 is a formidable combination but will kill you 5 speeder pretty quickly from the torque (been there done that with a 20g on a 2.5). I'd recommend a 6 speed conversion if you are aiming for anything over 400lbft of torque.
Alistair
Alistair
on a sensible note the 321 and 6 speed box will more and likely have to wait till next year , thought that combination would trash the box pretty quick, youve confirmed what i thought thanks alistair
kenny
going to be a hell of a motor once its all back together - you must be itching to get it done mate!
so youl have it all run in and at full power for next years highland fling then? ;)
  • 1 month later...
As the forum has been a bit quiet of late , thought id update my post on how my build is going . all the internals have now been purchased car was picked up and dropped of last monday but a few pics to be getting on wae for the time being
ej257 engine block
engine block ej257
manley con rods
arp stud kit
ej257 engine block
acl race spec shells
engine block
wiseco pistons
hopefuly there shouldnt be any major issues with the build will update as things progress
Edited by wrx kenny
