terzo neil Posted June 11, 2010 Posted June 11, 2010 where can i get a spare engine block cleaned prior to rebuilding it to my spec cleaned like gmac's chemically cleaned blocjk halves in glasgow or surrounding area
flat4phil Posted June 12, 2010 Posted June 12, 2010 How about trying one of the many powder coat peeps, as they use acid dipping to ensure metal is totally degreased and squeaky clean before that can coat it?
marky.t.s Posted June 12, 2010 Posted June 12, 2010 hire a power washer/chemical cleaner from Speedy Hire,they've got depots everywhere,i'm sure their number is on those red vans you see flying around.
terzo neil Posted June 12, 2010 Author Posted June 12, 2010 hire a power washer/chemical cleaner from Speedy Hire,they've got depots everywhere,i'm sure their number is on those red vans you see flying around. haha very funny got a pressure washer in the van and got tfr200 onboard for cleaning out radiators needing a complete chemical clean inside and out for fresh build
thebigfelly Posted June 13, 2010 Posted June 13, 2010 yeah any powder coat people. or even some metal plating places, as they use the chemical dips before galvanizing them (think thats the right word ) or am i thinking electro plating are you also planning on e-coat dipping them after the acid dip is done? this mite help also list of powder coaters in glasgow area ...sory if it doesnt just had a quick look for powder coaters http://www.upmystreet.com/findmynearest/se...category=Powder Coating Specialists&sort=6
wrx kenny Posted June 13, 2010 Posted June 13, 2010 hire a power washer/chemical cleaner from Speedy Hire,they've got depots everywhere,i'm sure their number is on those red vans you see flying around. brilliant kenny
colin_ross Posted June 13, 2010 Posted June 13, 2010 I wou;dn't be acid dipping any engine I was planning on using. Chemical degrease ok but acid dip.........
braveheart Posted June 14, 2010 Posted June 14, 2010 where can i get a spare engine block cleaned prior to rebuilding it to my speccleaned like gmac's chemically cleaned blocjk halves in glasgow or surrounding area I know its a bit far out Stevie Whitson in Penicuk has a machine to do the cleaning, SW Motorsport..
Jon B Posted June 17, 2010 Posted June 17, 2010 get yaself a plastic 25gallon drum, cut it in half and fill it with acetone, stick ya block halfs in one by one and leave to soak in it for bout 24hrs.... job done... anything it doesn't shift will come of with a scrub wi some acetone and some wire wool.... simples.
colin_ross Posted June 17, 2010 Posted June 17, 2010 get yaself a plastic 25gallon drum, cut it in half and fill it with acetone, stick ya block halfs in one by one and leave to soak in it for bout 24hrs.... job done... anything it doesn't shift will come of with a scrub wi some acetone and some wire wool.... simples. If you're going down that route then vinegar is much easier to get hold of and a fair bit cheaper too. http://www.cookhaus.co.uk/vinegar/index.htm
Jon B Posted June 18, 2010 Posted June 18, 2010 acetone aint too dear works out at £32 odds + vat for a 5 gallon drum which would more than enough...... cfs.net And at the same time you're guaranteed consistent results with it, as well as obviously being able to reuse it.
