frankyboy Posted June 4, 2010 Posted June 4, 2010 does anybody know where i can buy injector seals from phoned subaru and they dont have them in stock and will have to order them from japan which coukld take weeks
Phil MC Posted June 4, 2010 Posted June 4, 2010 (edited) I've got a load of Denso seals from topmount injectors you can try? Not sure if any will fit, but worth a go nonetheless? Did you manage to confirm that your #2 seal was goosed? Edited June 4, 2010 by Phil MC
frankyboy Posted June 4, 2010 Author Posted June 4, 2010 I've got a load of Denso seals from topmount injectors you can try?Not sure if any will fit, but worth a go nonetheless? Did you manage to confirm that your #2 seal was goosed? yeah took it out and the bottom seal had a wee nik in it so just to be sure i changed it with no 4 all my problems seemed to be sorted then started to smell petrol all the time then realise i must have niped the top seal when fitting it and it was leaking fuel
Phil MC Posted June 4, 2010 Posted June 4, 2010 When you get the replacement seals Frankie, you MUST ensure that you smear some vaseline or oil on the seals prior to fitting so you don't damage them again!!!
frankyboy Posted June 4, 2010 Author Posted June 4, 2010 Remind me of the model year of the car ? its a 1997 wrx wagon facelift
frankyboy Posted June 4, 2010 Author Posted June 4, 2010 What about Carl Davey? dont know who he is have you got a website or phone number for him
feckdeamon Posted June 4, 2010 Posted June 4, 2010 (edited) http://carldavey.co.uk/ Top feed or side feed injectors? Just noticed it's a 97 - standard injectors are side feed, newage topfeed lower seal's won't work but if they're topfeeds designed for a classic they might. Edited June 4, 2010 by feckdeamon
frankyboy Posted June 5, 2010 Author Posted June 5, 2010 Have some here, pop up and get them. cheers mate can you pm me your number
