Carbon Fibre
hi folks, just thought id ask a question. ive had a carbon fibre boot and spoiler on my car now for over 2 years, and have noticed over the last month or so the bootlid has started to loose its laquery fininsh, whereas the spoiler still looks as good as new, now i know that the 2 items are made from different companies, and that the building process is different, but i use the same cleaning products on them, and i just thought id ask if any of you know of a way of getting its gloss back with out relaquering it. i must also add that i have not polished it , just used a little quick detailing spray on it. thanks for any advice given... rich....
best and only way is to rub it back and re-laquer it.
you will have to rub all laquer off first with some good "high grade paper".
not wet and dry,or shop brought sandpaper,it will damage the carbon and the weave....!!!!!
if you need some i got a couple spare,i'll send you some..
if you have a local bodyshop they might give you a bit.
cheers chris
If it's faded that quickly it's probably gel coat rather than laquer. Like chris said, the only fix is to CAREFULLY sand it back and go over it with a top quality laquer
cheers for the advice chaps, as it happens i have a good bodyshop down my road, but havent had time to ask them before. i will ask them what they can do for me.. thanks again... rich....
