Sti Steering Wheel Swap
hi guys does any of you know how easy this is to do ,just a bit scared when i do it the airbag goes off knowing my luck it will any help much appreciated cheers i want to swap a wrx to sti 8 on a blobeye
People do this all the time in the US, even between newage and classic models. The wheel should be plug-and-play, so if the connectors are the same, you shouldn't have an issue.
As far as the airbag goes, just make sure you disconnect the battery and leave the vehicle sit for at least 3 minutes before tampering with the airbag.
