Advice Prior To Starting Motor
no fuel been in the system for about 6 months. Been advised i should crank the engine with the spark plugs disconnected (to allow fuel to get through the injectors and into the system) then re apply the sparks to get a light.
this good advice or rubbish? Can i just reconnect the lot n it will eventually feed fuel through after a few 20-30 second bursts?
roger!
the crank angle sensor that was SUPPOSED to be delivered today should be here am tomorrow. (next day delivery my a***)
so hopefully tomorrow B):D
Also a good idea to do this after a rebuild to get the oil round the engine before rinning it.
Fraz. :lol:
As above, leave the crank sensor disconnected and crank it until the oil pressure light goes out.
Was the fuel drained from the system and if so why? Also is the fuel fresh or 6 months old?
fuel not drained, and its the same optimax that was in it before (101 a litre stuff :lol:)
I will crank it til the pressure light goes, cant wait for the posty! feel like a little kid lol
Edited by 2087
I take it this is after your rebuild. If so the fuel is not an issue it's the oil that is. You don't want to start a freshly built engine with no oil pressure.
I would ( if possible) keep the plugs out, disconnect the crank sensor and turn it over until the oil pressure light goes out. At the very least disconnect the crank sensor and as playsatan says crank it till the oil light goes out.
Johnny
The best thing you can do is this when starting your car
1. Open the door
2. Sit in the seat and make yourself feel most comofrtable
3. Put on your seatbelt
4. Place the key in the ignition
5. Ensure it is out of gear
6. Start the engine
7. Drive away after selecting gear and checking your mirrors
If this simple process doesnt work you could always slump back into your living room setee, unbuckle your trousers, kick your legs over your head and smoke your own rod.
Hope this helps, best regards
Man-With-men
1. Open the door
6. Start the engine
Man-With-men
lol this man speaks with great wisdom :D:)
1. Open the door
6. Start the engine
Man-With-men
:D:) :) :boldblue::lol::rotfl:
