Tubular Exhaust Headers
they standard headers seem to be quite restirctive over a certain ammout of horses or something like that john, tubular ones help the spool a bit and increase torque that why alot of people tend to use them or get the OE ones ported, if your looking to buy avoid the "EBAY Specials" like megan etc, i use the GT Spec II on mine they retain the scooby burble at lower revs
Cheers mate. About fitting, what's involved? Ramps and under the car?
yup just a ramp should do it, but i think you do need a remap to follow as your interfering with the atmospherical condition of the plutonium sulphate of the veroxide generator
You just made that up!
I was thinking about a level 4/5 performance upgrade and among the bits and bobs needed there's the 321T, headers, 650 injectors, oil cooler and CAI - plus of course the remap, so I wouldn't be going down that route without the map. :icon_pray:
DID NOT!!
:):D:( well ok then maybe i did, but i think you do actually need a map though :(
anyhoo i hope youve looked into a gearbox before you go for this next lot lol :D
Yeah, but I can achieve Level 4 with everything in place for the price of a gear box... :icon_pray:
or you can replace the box now and drive your car like you stole it with out the fear of "i hope the box dosent let go" going through the back of your mind every time you use the loud pedal :)
I was thinking about a level 4/5 performance upgrade and among the bits and bobs needed there's the 321T, headers, 650 injectors, oil cooler and CAI - plus of course the remap, so I wouldn't be going down that route without the map. :rolleyes:
Level 4 or 5? I'm only on stage 3.
When on stage 2 I had the new engine with the hybrid turbo and a set of ported OE headers but as mentioned they can seriously restrict you once you get to 400bhp. Just have a look at my dyno graph
The power should have kept climbing but flatlined as they were holding me back.
Dunc is correct in saying a remap will be needed though. Due to the volumetric and dynamic pressure changes, combined with the increased scavenging properties you'd hopefully attain through effective thermal management it's a bit of a no brainer really.
Level 4 400-420 bhp
Full Decat turbo back 3” bore exhaust system
Tubular exhaust headers and flow matched uppipe
Walbro 255 l/hr uprated fuel pump
EcuTek custom remap
Custom Cold air induction
650cc Injectors
AFP 321T custom turbocharger with fitting kit
NGK uprated spark plugs
I know of the need to remap the car with the OE headers removed, but I have no intention of adding replacements on their own. I was thinking about a new turbo unit and what gains I would get from such a turbo and as can be seen from the above (level 4). headers would be required along with a host of other things. It was just that I didn't know what headers were, which I still don't, not really, hence the reason for the post initially. I'm going to stab a guess at it and say that headers are the pipes connecting the engine block to the uppipe through which. exhaust gasses flow. In other words, the first point of exit for exhaust gasses.
:rolleyes: headers are exhaust manifold that connect to the exhaust ports on the heads of the engine.Then you have the uppipe that connects between the headers and turbo.
Hope that helps you mate.
But seriously John...if you go for the MD321T turbo you will need to look at a gearbox shortly after.
Good luck mate
Level 4 400-420 bhp
EcuTek custom remap
650cc Injectors
Dooooooooooooooooooooooooooooooooooooooooooo it! Get a gearbox too though! haha!
Good luck mate
I would second that John..
Yeah I third it, but that is running to a 4k+ bill... I suppose I could up the power and not use the car on track until I have the gearbox sorted out but who knows when that will ever be.
Patience John, '' Rome was not built in a day'' things will come togeather sooner or later, just enjoy wot you have at the moment.. and spend wisley i made some mistakes and have paid for them.
Regards
Chris
Regards
Chris
Cheers Chris. I was thinking though, even if I fitted the turbo without all those other bits, I could still get the car mapped to run a little more than the 340 at present, then when funds allow, I can add the other parts as and when I have the cash and gradually turn the wick up on the map. I'll need to see if someone is selling an MD321T for a bargain though :rolleyes::D:rolleyes:
I take it a new GT30R with the up-pipe and a turbosmart wastegate for the same price as AndyF advertises a MD321T isn't an option?
£1250... na, dunno anything about the said turbo :rolleyes:
You can read about them here on Andy F's turbo advice page.
Edit - the Turbo is the one second from the bottom, and has 2 of the 3 bits required to fit it - the RCM rotated up-pipe with seperate pipe for a Turbosmart race spec external wastegate. Just needs a downpipe after that.
Edited by craigdmcd
