Engine Prezzys
I'm feeling guilty as the cars been off road for nearly a year, I'm looking for the correct order of maintenance I can follow to regain her fitness safely again. The list of products I have are as follows
Millers engine and box oil - with flush
Slick50 gearbox treatment, engine treatment and injector cleaner
Fuel filter
Oil filter
HKS high flow air filter
Magnicor HT leads with NGK sparks
Front and rear disks and pads and dot fluid
GUNK engine cleaner
The cars been turned over regular and lapped round the estate etc to keep her ticking over. And regular wd40 on parts I thought would need protected by dampness.
Any help would be appreciated. eg what to look out for when 1st driving, lube points "shut it mic" order of when to use the treatments etc.
thanks in advance :)
Chris
How could you forget me santas, i was right there :)
Ah well a got it 4month later :hyper:
ooooo myyyy
Edited by Carson
what about opening the credit card bill first :hyper:
anyways... cant you just whack the lot of it in there at the same time?
im hoping it would be that easy imy, I just dont want any "oooh mys" if the flush dosnt agree with the treatment etc. I just dont know :)
anyone used these treatments before on gearbox / engine ?
Edited by Carson
Yeah the engine one is a piece of piss. Stick it in the oil go for a drive 10 - 20 miles at medium revs > go home > do a poo > jack car up from passenger side > sump plug out > let the oil all drain out > pre fill your new filter > bung the new filter on > fill up the engine > check levels > allow 10 mins to settle > start car and then smoke some chavs. Done.
PLEASE GOD - DO NOT USE THE SLICK 50 ENGINE TREATMENT!
BAD NEWS ALL ROUND!
Everything else is fine but NOT THE SLICK 50 ENGINE TREATMENT!
Russell
Engine treatment stuffs is binned. Am not going to question it :thumbup:
  1. Am going to run the car with the millers flush, then stick in the new stuff and do the box oil.
  2. V-power the full tank with the injector cleaner.
  3. new plugs / ht leads / 3 filters installed.
last 2 things am not sure on! Gearbox teatment, that the same as the engine treatment? "wus: bad all round "
And
lubrication points? eg areas that might have got seased or need 0 friction to operate right
Chris
How could you forget me santas, i was right there :thumbup:
Ah well a got it 4month later :banana:
ooooo myyyy
Who's the Jakey on the right, and is that a glass in his hand ? :D
Edited by JohnSt
