Checking Oil
This is embaressing but, when I check my oil, one side of the stick says its low and when a turn it over, the other side says its just right! What is that about and what side do I go with? :angry::wacko:;)
The middle.
measure both halfs, measure the overall length of dipstick, divide by three and your level should be bang on.
Its not embarassing, its a good point.
I have seen this on my old uk turbo but I just went for a happy medium, as long as both sides were within the limits, and check it now and again!
Rich
I've got to admit, I found it impossible to get a good clear reading on my last car ('06 wrx), manged to overfill it. Spotted it thou and out with the drain plug.
I cannot believe how awkward it is to check the level. I now just aim for half way between. Anyone else have any tips?
Well its good to see that I#m not the only one have this issue.
The middle.
What did you measure it with ?
my sti is the same john i just take an average between them
Edited by young-buck27
yep noticed this on most of my scoobs.
Check 1 high
Check 2 low
Check 3 just fine
Just a tad annoying!
I can mind my 306 S16 had and oil level guage (used the oil pressure guage) when you turned the ignition on, was handy but being a ****ebag I still used dipstick occassionally!
This is embaressing but, when I check my oil, one side of the stick says its low and when a turn it over, the other side says its just right! What is that about and what side do I go with? :huh::wacko::P
The reason your levels are different on both sided of the dipstick is due to the angle the dipstick enters the sump, it doesnt go straight in but at a very steep angle, a result of this is that unlike most other cars where the difference between max and min on the dipstick is around 1 litre, the scoobs is only 1/2 litre (ish). As to what side to take the reading off, when you pull the dipstick out look at the left hand side this will be the top of the dipstick as it sits in the sump giving you the level of the oil, just ignore the other side :(
Cheers Iain
Edited by Big 'D'
Cheers Iain
I see. Cheers for that mate. I guess going for the halfway between the two idea, is the way to go.
J
