terzo neil Posted February 24, 2008 Posted February 24, 2008 (edited) right guys fired the car up today, ran fine, done around 4 miles and the CEL came on stayed on for another 5 miles driven gentley i mean gently, then CEL light went out sitting idling away the light came back on and touch the throttle and the light goes out Met Nanaki down in the Kilmarnock but his secs unit doesnt work on my car so couldn't read the fault code drove fine all the way home, no problems, but the engine noise sounds different above 5500 rpm, more like a blow on the exhaust, raspy any help appriciated going to check the codes by plugging in the black connectors if they are there under the dash tomorrow the car never stalled or cut out once Edited February 24, 2008 by Terzo Neil
craigo Posted February 24, 2008 Posted February 24, 2008 right guysfired the car up today, ran fine, done around 4 miles and the CEL came on stayed on for another 5 miles driven gentley i mean gently, then CEL light went out sitting idling away the light came back on and touch the throttle and the light goes out Met Nanaki down in the Kilmarnock but his secs unit doesnt work on my car so couldn't read the fault code drove fine all the way home, no problems, but the engine noise sounds different above 5500 rpm, more like a blow on the exhaust, raspy any help appriciated going to check the codes by plugging in the black connectors if they are there under the dash tomorrow lambda sensor poss.....
terzo neil Posted February 24, 2008 Author Posted February 24, 2008 lambda sensor poss..... just checked the ecu by the 2 black plug method by heck, trying to keep up with the flashing cel is difficult got error codes 33 - Vehicle speed sensor 2 45 - Pressure sensor / Pressure exchange solenoid valve and just reset the ecu as well by joining the 2 blacks and 2 greens together and a light drive with no boost, took around 3 minutes no faults stored, could have been dampness as not moved in over 3 weeks
terzo neil Posted February 24, 2008 Author Posted February 24, 2008 ran the car today been fine running normally, all the power is there god knows why it decided to throw the toys out of the pram
jimser Posted February 24, 2008 Posted February 24, 2008 ran the car todaybeen fine running normally, all the power is there god knows why it decided to throw the toys out of the pram the smell of diesel maybe????? sorry mate ,couldnt resist
