terzo neil Posted April 30, 2007 Posted April 30, 2007 right guys, was going to put back end loose, but the back end feels very skitterish lately checked the tyres, pressures and drop links all ok, have noticed over bump and imperfections on the road that the passenger rear seems to bounce a wee bit could my shocker be duff ?
the squiggle Posted May 1, 2007 Posted May 1, 2007 If the rear is taking a while to settle down then more than likely be a worn shocker
terzo neil Posted May 1, 2007 Author Posted May 1, 2007 cheers grant it takes a wee while to settle, when boot it you can see it squat a bit more than the other side
scoobaroo Posted May 1, 2007 Posted May 1, 2007 Id be more inclined to change your underwear first, especially if youve been feeling "skitterish" lately [] Marty.
terzo neil Posted May 5, 2007 Author Posted May 5, 2007 all sorted now changed passenger rear shocker and inner tube fell to the bottom and it is soaking all down the body as well didnt know the brake pipe flexi had to be discvonnected, cut the old bracket off the old shocker and cut a slot in the other shocker to slide the flexi thro
