Guest Posted February 16, 2007 Posted February 16, 2007 done a search about changing the oil and found out the easy bits like what oil new copper washer etc but can someone tell me what the crank position sensor looks lik? is it the one under the altenator and needs a 7mm spanner to get it off? cheers neil
euan_r Posted February 16, 2007 Posted February 16, 2007 yip its under the altenator. or if u wanted u could just remove the electrical connector. Btw this aint about priming the oil by any chance. Have heard this elsewhere and i wouldnt bother with it IMO.
Guest Posted February 16, 2007 Posted February 16, 2007 it is mate just heard a few funny stories thats all. why shouldn't i bother? went to halfords and as usual not got the filter so ill have to shop around or head to subaru in falkirk in the morning! neil
euan_r Posted February 16, 2007 Posted February 16, 2007 saw a thread on scoobynet about this. if u want to do it for your own mind then do it. I just fill up new filter a couple of times letting it settle then add oil through filler. thinking about it a bit more what they are suggesting is to turn over engine without firing it. probably more wearing in itself than just doing the usual setup.
cupradave Posted February 16, 2007 Posted February 16, 2007 when to halfords and as usual not got the filter so ill ahve to shop around or head to subaru in falkirk in the morning! if you can wait til next week, I got a Greddy filter from Graham Goode Racing, thier service is ace and they will have the item in stock and should have it to you in a few days http://www.grahamgoode.com/subaru/parts.ph...p=86&nav=83 [] P.S I didnt bother priming either and have had no problems or worries
Guest Posted February 16, 2007 Posted February 16, 2007 cheers dave need it done this weekend touching 3900 miles since the last one plus going up to aviemore for a boarding weekend next friday phoned subaru falkirk they have them in so ill get there in the morning. neil
coulty Posted February 16, 2007 Posted February 16, 2007 yip its under the altenator. or if u wanted u could just remove the electrical connector. Btw this aint about priming the oil by any chance. Have heard this elsewhere and i wouldnt bother with it IMO. Dear god!!! For all the time it takes to crank the engine over after disconnecting the crank sensor. It's your car but for the sake of 1 mins work i would rather not risk the cost of a rebuild but suit yourself!!!!
euan_r Posted February 16, 2007 Posted February 16, 2007 sorry but never heard such a load of *****. have ran and continue too, a lot of high mileage(150K) flat 4s and never had any problems what so ever. do you think this happens in any garage, dealership or otherwise? the difference is nowt either way tbh. its just anal
coulty Posted February 16, 2007 Posted February 16, 2007 sorry but never heard such a load of *****. have ran and continue too, a lot of high mileage(150K) flat 4s and never had any problems what so ever. do you think this happens in any garage, dealership or otherwise? the difference is nowt either way tbh. its just anal
coulty Posted February 16, 2007 Posted February 16, 2007 sorry but never heard such a load of *****. have ran and continue too, a lot of high mileage(150K) flat 4s and never had any problems what so ever. do you think this happens in any garage, dealership or otherwise? the difference is nowt either way tbh. its just anal It is not anal. It has been proven throughout scoobynet that a lot of failures occur within 50-100miles of an oil change. You may have just been lucky that you have not seen any problems but there have been many that have. I say for all the effort of disconnecting 1 plug and cranking it for 30 secs before firing it will not kill you anyway!
frank c Posted February 16, 2007 Posted February 16, 2007 Can't say i've ever done anything but primed the filter,filled the engine with oil , started the car and drove away, but i'm no expert. No oil light came on either, if that matters. ? Point taken Coulty, i'll try it the next time matey
Guest Posted February 17, 2007 Posted February 17, 2007 calm down peeps ill go the whole anal way everytime if it saves my engine i just wanted to know what it looked like (crank sensor) neil
cusco kid Posted February 17, 2007 Posted February 17, 2007 hi m8 if you value your engine fill your filter to prime it crank the engine with the sensor disconected then reattach then start up its worth it trust me ask andy f engine builder he should know also i do it all the time on my wrx 300 and add teflon which helps with cold starts geo
Guest Posted February 17, 2007 Posted February 17, 2007 teflon? additive? im quite new to subaru so im not up on the lingo just yet neil
cusco kid Posted February 17, 2007 Posted February 17, 2007 hi neil teflon is ptfe the non friction additive for use in engines g/boxes diffs and polishes its non stick like frying pans for example //////// added to your engine it coats all internal tarts and lubes bearings in initial start up till oil preasure comes up therfor no scuffing of surfaces occur see posts for teflon polish many people have tryed it on this site and love it some have to rubbish it but i will side with the many posters that like- swear by it geo[Y]
