Wheel studs question:
Folks,
I bought a set of wheels from Brian (WRXMANIA) and I fitted them at the weekend just to see how they feel etc. However, the nuts I have from my own wheels don't properly fit the new wheels. The countersunk well on the new wheels is not deep enough to take the stud and is therefore sitting proud of the wheel face (:D, instead of how they should sit (A). Is this unsafe? Should I get the right studs and where can I get them?
Diagram
Wheels fitted
I'm a wee bit comfuse on what you are trying to say.
I would say B is the correct nut for the silver wrx wheels.
Which nut came off the gold wheels?
The B nut is the nut that came off of my gold wheels, the ones in A are the ones I am guessing are the right ones judging by the markings on the wheels. I think the angle of the countersink is the same to answer your question drb5. or close to it!
Well i have a couple different style of wheel nuts here, your welcome to try out. Not sure if they are all full sets mind you, but at least it gets you closer to settleing your mind....
At the end of the day, alloy is soft and by tightening it up enough, you shouldn't have a problem. Just don't tighten the locking nut up too much! [:D]
Thanks mate. Next time I am out your way, I'll drop you a PM and if you can set me up then that will cool.
J
hi m8 i use these wheels on my track car  nut B is the correct nut to use nut A could possibly bottom out on wheel
face just in case kick them into touch geo
