Auldy Posted December 12, 2006 Posted December 12, 2006 cars goin off the road over the xmas period for new clutch and flywheel so gona give it a service while im at it! jus wondering which plugs and oil i shud use?? read sumwer that recommended NGK7's and motul 15/50w any feedback wud b helpful [Y]
WUZ Posted December 12, 2006 Posted December 12, 2006 NGK PFR7B's for STi's and 15/50 Motul 300V is what I recommend for your car and it is what I use in most of the cars I work on! Russell
frank c Posted December 12, 2006 Posted December 12, 2006 4.5 litres rings a bell but i'd need to check.
WUZ Posted December 12, 2006 Posted December 12, 2006 4.5 litres rings a bell but i'd need to check. COOOOOOOOOOOOOOOOOOOOOOOOOOOOOORECT! - make sure you fill up the Oil filter several times to ensure the Oil has soaked into the filter before topping the filter up and putting it on the car. You should be able to put in about .half a litre of Oil into the filter. Russell
Auldy Posted December 13, 2006 Author Posted December 13, 2006 cheers guys [Y] so ther any suppliers out ther of this motul stuff?? was gona order it off the net or demon tweeks but prob easier if bought it off sum1 closer
~ ~ Cal ~~ Posted December 13, 2006 Posted December 13, 2006 WUZ - could I get away with using 6B's or would I need NGK PFR7B's ? Thanks Cal
WUZ Posted December 13, 2006 Posted December 13, 2006 WUZ - could I get away with using 6B's or would I need NGK PFR7B's ? Thanks Cal Cal - I TOLD YOU THIS MONTHS AGO M8!!!!!!!!!!! 7's would be a wiser choice for you. Russell
WUZ Posted December 13, 2006 Posted December 13, 2006 Auldy - 5 litres of Motul 15/50 - £40........delivery £10 (due to weight). Russell
