scoob fae ork Posted December 12, 2006 Posted December 12, 2006 Hi everyone im quite new to Scoobys but im a proud owner of a 2004 Impreza STI altho the car is just fantastic i have come along a small problem . The low beam head light bulbs blew so i changed them but the lights still dont work and i have checked all the fuses and all the relays but still no joy . Does anyone have any ideas ? any help is more than welcome . Regards Donald
thewelsho Posted December 12, 2006 Posted December 12, 2006 Welcome mate. No clue about your bulbs, sorry. If its not fuses or bulbs it would appear to point to an elecrtical fault. Showz your car when you get the chance.
AVI_8 Posted December 12, 2006 Posted December 12, 2006 I would check the connections first then the bulb again to make sure that the filliment hasn't blown on the new one, if their ok check for voltage at the connection plug, you can get a cheap tester for a few quid from a car accessory shop, if theres no voltage pull the correct fuse from the box and check for voltage there, the problem will lie somewhere down the line.
scoob fae ork Posted December 13, 2006 Author Posted December 13, 2006 Woo Hoo got the car fixed again it wis just a bad earth. Thankyou for the help . Al get the car cleaned up an get picks on here o it . Cheers Donald
st3ph3n Posted December 13, 2006 Posted December 13, 2006 Donald, where's your troosers? Wait, that was skye wasn't it? Anyway, welcome to the club mate.
