need more help
Right been on here and scoobynet had advice off loads of people spoke to andy f.Let me know what you all think this is what i am going to get built.
1 2.0 closed deck block
2 forged pistons and rods uprated bearings
3 uprated oil and water pumps
4 ver3 sti heads
5 20g turbo
6 apexi
7 3inch exh turbo back
Let maknow if a need anything else this is my starting point thanks also does anyone know if my block will be okay to use aswell as my crank as the big ends went only ran for a couple a seconds
Uprated fuel pump and regulator
550cc or preferably 740cc injectors
AVC-R Boostcontroller
Porting of the headers or preferably a set of decent aftermarket items
Decent induction
Uprated MAF sensor
Decent Intercooler of the front mounted variety
Lag all your exhaust parts
Fit Exhaust Gas Temp sensor to the up pipe
Vent crank and cam breathers to atmosphere
then when your gearbox craps itself a Phase 2 box or preferably an uprated gearbox and clutch
then when your car starts to suffer from fuel starvation under half a tank, a custom swirl pot setup
mines been having serious problems when below half a tank, does the custom swirl pot set up cure this ?
Yes it will, not cheap but very effective
There is cheaper Heath Robinson type methods available but i would go for a decent swirl pump set up
You'll be lucky if your block only needs a hone and your crank will most definately need replacing.
how much is it to get the block honed and any ideas the price on a crank cheers
You wont know until its looked at, a new crank isnt that dear, you could get it treated to make it even harder as well, if your crank is gubbed and you need to use it a regrind and acl oversized bearings is a good move. Dont listen to any horror stories I know many people who have done it to good effect and no dramas.
Callum
