help with my project WRX
What's wrong with wanting a wee bit of noise?
The topmount may be a good precautionary measure.
i may spend the money on it onstead of a sportcat lol.
does anyone know what the fine is etc if you get pulled for emissions?
  • Replies 91
  • Created
  • Last Reply
Top Posters In This Topic
as far as i know you cant be fined for failing a road side emissions test, i think they give you a week to get it sorted , if you get stopped after that then your for the high jump
It's bit of luck at the end of the day, but they are a bit brittle and with high boost, the compressor blades can break off and do some pretty major damage.
[;)] not so good. I'm not going to be running high boost so will do the job for now.
The Troll [:)]
Obviously some VF turbo's are more robust than others, but i've of some, not being able to take much more than 1.5 bar. As long as you run everything by Andy before mapping, he'll be able to keep you right.
[H]
[H]
Its the VF35 i've got and a local cowboy doing all the tuning work for me, then it will be finished off with a Andy F map so it will be set up 100% [;)]
Of the "old school" VF series Dave i.e. VF28/24/23/22, the VF22 was the most fragile and tended to break the compressor blades when boosted repeatedly.
The rest were okay as far as i am aware but what put them out of favour was the TD series of turbo's which AndyF campaigned to the masses and are still a top choice many years later.
I was party to some testing one late night many years ago with AndyF and John Banks where we did back to back testing on a hybrid VF23 and a TD05 (changing the turbo in a barn next to some coos!!) and the TD05 was the better and cheaper option. This started the death knell for those type of VF series turbos.
I used to have a VF23 and it pulled like a good un, BUT ....... on the way home from getting the car mapped i kicked a blade from it and didnt even make it home, lol. But my mate hade one on for ages and his car went great, i guess its just your donald at the end of the day [;)]
Of the "old school" VF series Dave i.e. VF28/24/23/22, the VF22 was the most fragile and tended to break the compressor blades when boosted repeatedly. The rest were okay as far as i am aware but what put them out of favour was the TD series of turbo's which AndyF campaigned to the masses and are still a top choice many years later. I was party to some testing one late night many years ago with AndyF and John Banks where we did back to back testing on a hybrid VF23 and a TD05 (changing the turbo in a barn next to some coos!!) and the TD05 was the better and cheaper option. This started the death knell for those type of VF series turbos.
Cheers Alan.
What's the views on the newer version?
Instead of a sports cat which are expensive and unproven over time just get an old centre section made up with an extra cat in for mot easy solution max output minimum input.
I don't have much, if any, experience of the newer versions Dave, though as development progresses over the years i'd imagine they would be much improved over the earlier versions.
From what i read, as many of you guys do, they are pretty good units in their own application, though they tend to be fitted on the Newage cars which isn't really a fair comparison over the classics when they're out on the road.
Turbo of choice imo for the classics, still appear to favour the TD series.
thanks to everyone for their help with this.
i have made my mind up and the 18g it is.
Hopefully by February next year i wll be finishing this project off.
I now have sti pink injectors, a walbro fuel pump, a brand new magnex up pipe and defis on the way as well as a knocklink.
only the expensive parts left to buy now.
well i now have a few pieces sitting waiting to get fitted
STI PINK INJECTORS
WALBORO 255 FUEL PUMP
MAGNEX UP PIPE
HKS DECAT DOWNPIPE (YES YOU READ IT CORRECTLY)
DEFI BF BOOST, OIL TEMP AND OIL PRESSURE
KNOCKLINK
Now all i have left to get is 18g turbo, aps cai, sti topmount intercooler and an AndyF ECUTEK remap and a new clutch.
