Fee Posted August 29, 2006 Posted August 29, 2006 I'm getting so confused! Everything I read says something different. So I'll start from the beginning and hopefully someone can just tell me what I need to know! I have a 1997 WRX STi TypeR (R reg) (oh, and does that mean its a STi IV or V???) I'm trying to figure out what steering rack I need for the car (or have on the car at the moment)....if I need a quick/short rack Some posts say that all TypeR's have a quick rack as standard.....others say only the V limited do. AWD have said that I have a standard rack but a "STI QUICK STEER SYSTEM"....is this the same thing? Just got Adam at home to turn the wheel lock to lock....and it turns 2 and 3/4 times...this may be helpful if I knew what a standard rack should turn! to me that would suggest a standard rack though (but I'm just guessing) I've also spoken to Subaru who have said that the rack for my car is the same as the P1...although I've read posts stating otherwise....is this because it is actually the same rack but without this STi quick steer system? If it is the same rack....can the steer system be taken off one and put on another? Essay now over......please someone explain to me in dummy terms wtf this is all about!!! Thank you [:^)]
colin_ross Posted August 29, 2006 Posted August 29, 2006 First off, your car is an STI 4. The quick rack was standard on some models but not the type r however it was an option so you could have either. Not sure how many turns they are lock to lock but 2 3/4 sounds like a normal one.
darryll Posted August 30, 2006 Posted August 30, 2006 fee your car should have the quick rack mine has and also need a new 1. i bought my first rack from glenburgie secondhand and its only lasted 1 yr cost me about 140quid aswell im gutted .i think dingbro do them new for £280 but im a bit unsure let me know how u get on .oh almost forgot had to make a special spanner to get the power steering pipes off (just bend a spaner lol).
akcwong Posted September 29, 2006 Posted September 29, 2006 So you can actually get the UK Supplied Steering Rack right? Or must replace by the quick rack from JDM STI RA?
