Any Ideas? Least Expensive Boost Control Device?
Hello, Could anyone suggest a suitable replacement 'aftermarket' boost controller - perhaps Turbosmart product or
similar - preferably one you have fitted or did fit - on a pre 1998 Classic?????
That was quick! Sounds good - but what device is it and how is it fitted (engine bay/ dash)? Yes I have a boost gauge - but no idea how accurate it is.[:$]
Thanks.
It's the same as a Dawes valve, or similar.
I just installed on to my friends the other day and found it easier to setup than a Dawes and quicker finding your desired boost.
What sort of boost gauge do you have and do you have an AFR meter, or Knocklink?
What sort of car do you have, with what mods?
The boost gauge is a low rent dial gauge, and no I don't have any separate air fuel gauges or additional knock link.
Mine is a UK 97 Classic; front mount, GEM's implant ecu board with the anti-lag (takes manifold absolute pressure - not MAF), plus usual
Walpro, fse, yellow injectors, and I believe a stock IHI turbo, 'turbo back' decat system. I know that the boost is currently subject to the stock solenoid type
valve - and perhaps could help if changed - but to what & without spending Apexi money?[:$]
I'd have thought the boost control was good with the GEMS, but i'm sure if your careful enough, this valve could be just as good.
Up to you mate. Speak to your mapper, if your not sure.
Thanks for the reply. It was following my last RR (not at a GEM's specialist though) that the operator suggested I look into an aftermarket boost control device, perhaps electronic, to replace the stock solenoid valve. Just hoped there were gizmo's around that didn't all cost Apexi Power FC money or similar.[:D]
This valve does work better than the stock solenoid, yes. Car is a bit more spritely and holds the boost better.
Theres a wee leaflet supplied, but i'll let you know how's best and easiest way to install and setup.
Send me a PM if you defo want it mate, cheers.
