chris_c201 Posted June 12, 2006 Posted June 12, 2006 Just looking for clarification on something...... The dipstick to the right of the turbo is your gearbox oil dipstick right? If yes then i need to top up my oil as its barely registering on it, next two questions - 1 - Do i just buy regular gearbox oil, any specific things to look for / avoid, where to get? 2 - Where is the filler and roughly how much should i need ? Cheers Chris
dougster Posted June 12, 2006 Posted June 12, 2006 75w 90 semi or fully synthetic oil (millers) and you need to fill it via the dipstick which is under your I/C on the turbo side.
chris_c201 Posted June 12, 2006 Author Posted June 12, 2006 75w 90 semi or fully synthetic oil (millers) and you need to fill it via the dipstick which is under your I/C on the turbo side. Cheers Doug, any tips on how to get it in there without spilling / removing intercooler, altho i have a Samco intercooler hose on the way, maybe do both at once.......
dougster Posted June 12, 2006 Posted June 12, 2006 You'll need a fairly long funnel to do a tidy job.
johnnyr6 Posted June 13, 2006 Posted June 13, 2006 A big syringe will also work, plenty lying around the local parks...lol Other option as dougster said is a funnel but attatched to a hose or thin pipe.
gus the bus Posted March 28, 2007 Posted March 28, 2007 How much gear oil will I require for g.box and rear diff? IIRC it is 1 litre for diff and 3.5 litres for box??? Gus
